75 rear window mod
Old Jan 3, 2019 | 07:05 PM
75 Driver's Avatar
75 Driver
7th Gear
Default 75 rear window mod
I pulled my rear glass out for the flo-thru. Today I found a removable glass assembly from a 68 and the thing popped right in. Even the holes for the window frame stubs were a perfect match. Does anybody know if the weather-strips available online will also fit into my 75. I've owned a lot of Vettes and have not seen this conversion. I hate to order the weather-strip and finds a big oops.
Old Jan 3, 2019 | 07:44 PM
jkippin's Avatar
jkippin
lots of write ups on this mod. Very easily done all the latches bolt in pretty much some need to drill the holes for them an use u nuts. The gasket works with little to no cutting. I did mine myself in a few hours and I did not have to cut the gasket to fit others have had to. I did the full conversion on mine but took the window tray out decided I didn't want to use it
Old Jan 3, 2019 | 08:39 PM
75 Driver's Avatar
75 Driver
7th Gear
Thanks, I'll search the posts. I didn't find any on my first try.
Old Jan 3, 2019 | 08:51 PM
John 65's Avatar
John 65
I did this mod to my 77 years ago and the weatherstrip glued up just fine as is right out of the bag.
Old Jan 3, 2019 | 08:57 PM
John 65's Avatar
John 65
A few good pics here.
https://www.corvetteforum.com/forums...installed.html
To 75 rear window mod
