Engine type
Old Jan 5, 2019 | 12:36 AM
plafonta's Avatar
plafonta
Default Engine type
Hi
does anyone know how you would determine what type of engine a c3 was original supplied from factory with?
Old Jan 5, 2019 | 08:27 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The base engine for all C3s was a small block Chevrolet; 327 CI for 68 and 350 CI for all other years. Higher horse power small blocks were optional. Until they were discontinued, big block engines (427 or 454 CI) were optional. Do you have any original documentation with your car?
Old Jan 5, 2019 | 10:42 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
starting in 71 the vin tells you the engine it was born with.
Old Jan 5, 2019 | 11:24 AM
Dynra Rockets's Avatar
Dynra Rockets
for a 68-70 you will need a tank sticker to be 100%. Without a tank sticker you have to look for tale-tell signs such as fuel lines, tach redline, HD differential, etc.
Old Jan 5, 2019 | 11:41 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Originally Posted by plafonta
Hi
As others have already said, depends on the year. Assuming you’re asking for a specific car, post the year and what’s in it now and we’ll go from there. As a for instance, for a 72 LT-1, the VIN will tell you what the original engine was but for a 70 LT-1, there are pages of clues that you have to work through. Without original documentation, hard to be definitive on these.
I think the VIN shows the motor in the 1972 model year, manufactured late in 1971.
Old Jan 5, 2019 | 07:42 PM
riverracer au's Avatar
riverracer au
there's a vette club in Geelong
they would have some knowledgeable people that could give the car the once over for you.
Old Jan 5, 2019 | 11:22 PM
plafonta's Avatar
plafonta
Sorry I should have been more specific. I know it's a 350 but was it a standard 350 or an lt1? And it's a 71
Old Jan 6, 2019 | 12:30 AM
CA-Legal-Vette
If it’s a 1972, easy enough: the fifth digit in the VIN would be a K for the base engine and an L for the LT-1 (255 HP that year). For the 70 and 71 models, no such definitive reference but rather clues. There are different tachometers, ignitions and differential ratios but a simple clue is that LT-1s only had a single fuel line on the passenger frame rail. The stock 350 had two, a feed and return line.
Old Jan 6, 2019 | 02:16 AM
AUS72's Avatar
AUS72
How close is it to being on the road? I have the corvette black book if you want a look.
Old Jan 6, 2019 | 07:13 AM
nutsy's Avatar
nutsy
I believe in 72 if it was a big block there is a W in the vin. when I decoded my 71 big block I didn't see anything that specified engine size.
Old Jan 6, 2019 | 08:38 AM
Easy Mike's Avatar
Easy Mike
...I know it's a 350 but was it a standard 350 or an lt1? And it's a 71...
There is a pad on the block at the front of the passenger's side head. There should be two stampings on the pad. One identifies the engine and the second is the VIN derivative of the vehicle the engine was originally installed in.
Here's a sample of a pad.
Old Jan 6, 2019 | 02:12 PM
jackson's Avatar
jackson
OP
How do you KNOW it's a 350...Could be any size sbc someone may've replaced original motor. Start by getting the code/numbers off that pad.
Old Jan 6, 2019 | 04:23 PM
jackson's Avatar
jackson
1971 C3 w/ sbc
Three letter code beginning with C followed by two letters
Old Jan 6, 2019 | 04:37 PM
monteholic's Avatar
monteholic
its been a long time since I've owned a C3, but isn't there a tag on the console that says what engine was in the car?
right below the shifter
Old Jan 6, 2019 | 05:30 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by monteholic
...isn't there a tag on the console that says what engine was in the car?...
Yes and no. The last thing to rely upon is the console plate since they are easy to change. You can make your car into an L-88 by adding the L-88 plate if you want. The engine suffix code is the most reliable ID.
Old Jan 13, 2019 | 05:36 AM
plafonta's Avatar
plafonta
Default Hers the stampings
Old Jan 13, 2019 | 08:08 AM
BKarol's Avatar
BKarol
Because of the shape of the pad it is a mid 77 or newer block. This is what the pad should reveal. Can't figure out what they did to yours.
To Engine type
Old Jan 13, 2019 | 08:34 AM
Easy Mike's Avatar
Easy Mike
I agree. Wrong pad for a 71.
Old Jan 13, 2019 | 09:19 AM
derekderek's Avatar
derekderek
is the yellow in the stamping or highlits added by you? it is an obvious attempt at restamping. poor attempt. CGZ is 71 corvette LT1. such a bad job they may as well have used an L88 code. wouldn't be much less believable.
Old Jan 13, 2019 | 10:33 AM
jackson's Avatar
jackson
Per others...pad and characters are entirely bogus.
I suspect chicanery afoot here...or worse.
About the only way you can positively ID this red-headed stepchild is by disassembling it; be prepared to learn it's not sugar but chit.
