Cleaning Cast Aluminum?
Old Jan 9, 2019 | 07:03 PM
HeadsU.P.'s Avatar
HeadsU.P.
Default Cleaning Cast Aluminum?
Picked up a cast aluminum tranny pan off Ebay. Has a couple fluid stains on the outside because it is used. Anybody know of a concoction that will clean that? Being that its cast, it has a very rough texture.
Old Jan 9, 2019 | 07:35 PM
Jeffs82c3's Avatar
Jeffs82c3
Glass bead sandblasting.
Old Jan 9, 2019 | 07:44 PM
Gold Dragon's Avatar
Gold Dragon
Mag cleaner, or magnesium cleaner. I think Eagle still makes it. Just make sure it doesn’t touch anything else. It will ruin a painted surface. But man it will it brighten the aluminum.Use a soft wire brush to get into the tight spots.
Ray
Mooser's Avatar
Mooser
Lots of the "toilet bowl" cleaners will work on aluminum (boat guys using them on pontoons etc forever
One of the ones commonly recommended is called "the works" and another is "L.A.'s Totally Awesome" and is available at the dollar stores in the USA
Personally I use Flitz pre-cleaner
M
Old Jan 9, 2019 | 07:52 PM
HeadsU.P.'s Avatar
HeadsU.P.
That makes sense. No body we see the pan but me. I just want to clean it because.
I got the pan for a song, about half price used.
Old Jan 9, 2019 | 07:58 PM
Mooser's Avatar
Mooser
Just because nobody sees it doesn't mean it can't be nice
M
Old Jan 9, 2019 | 08:28 PM
jackson's Avatar
jackson
cast alum is very porous and any caustic will tend to adhere and corrode if not neutralized/flushed well. If not, can darken aluminum.
Oxalic acid (powder) (DAP / Savogran Wood Bleach) mixed in water. This same as the old fashioned OTC radiator cleaners that're no longer available.
Neutralize with baking soda mixed in water then lots of rinse water.
-edit- deal or not, and no doubt plenty do, but I'd hesitate running a cast trans pan on a low-slung street driver.
Old Jan 9, 2019 | 09:05 PM
Motorvation's Avatar
Motorvation
https://www.google.com/search?q=east...EW&pie=plaji-i
This stuff works excellent. But is expensive. Spray on, rinse off. Smells like the old green Metal Prep.
Steve O.
Old Jan 9, 2019 | 09:44 PM
forman's Avatar
forman
e-z off oven cleaner works well use a plastic brush to scrub ,, dont used a wire brush It will leave fragments of rubbed metal on the aluminum and Will rust ,, ask me how I know
Old Jan 10, 2019 | 03:06 AM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Bar keepers friend and a nylon bristle brush. What's left over works for many uses around the house!
I use to clean alternator cases and 78 aluminum power antennas.
Old Jan 10, 2019 | 08:37 AM
HeadsU.P.'s Avatar
HeadsU.P.
Yes, speedbumps will be my nightmare with a deep pan. However, the header collectors will be the lowest part to scrape first. I want some extra (cooling) volume of trans fluid with the 3,000 stall. Have a trans cooler out front also.
Update: Just measured.
For those who care, the 2 Qt extra capacity, deep tranny pan is 1+5/8" lower than stock on a TH350. So, not too bad for grd clearance.
Old Jan 10, 2019 | 09:24 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Why not just buy a product specifically to clean aluminium such as Alumabrite or Aluma Kleen?
Old Jan 10, 2019 | 10:26 AM
Scrrem's Avatar
Scrrem
I had good luck cleaning my rear axle case with aluminum wheel cleaner.
Rich
Old Jan 10, 2019 | 12:07 PM
540 vette's Avatar
540 vette
I use cast wheel cleaner. Makes it look new.
To Cleaning Cast Aluminum?
