hello ,I have a set that came off of a 79 good shape ,the problem is im in florida till feb.28 then back to michigan ,if I can help you out let me know! Bill
I rebuilt my hinges with the new pin & bushings kit. Tightened everything right up. I took my doors off to do it but I had a lift to use to help re-install them. They are very heavy, do not hurt yourself.
I used a tool bought on Ebay to hold the door. It fits on a floor jack. See photo.
I took the door off and replaced the hinge pins and bushings.
Tape the edges of your fender and door.You can mess up the paint if not careful. Don't ask me how I know that?
If I did it again I would have a helper. Two people.
That looks awesome Craig, now I want one. Ill try to post a picture of what I had to go through. thinking it better to not try and pull around on the power window wires to remove them to remove the door.
