C3 air conditioning
Old Jan 25, 2019 | 09:36 AM
vettamunga's Avatar
vettamunga
Cruising
Default C3 air conditioning
Hey gang
i am am looking for an air conditioning solution tfor my C3. Prior owner completely gutted the AC. Nothing except interior vents and interior console slider panel.
Vintage Air seems to have a nice upgrade kit. Anyone have any luck with these? A little pricey at about $1500 but I assume a stock restore would be higher.
Old Jan 25, 2019 | 10:47 AM
Tampa Jerry's Avatar
Tampa Jerry
Default Vintage Air
Go with the Vintage Air. I installed VA in my black/black 66 coupe in Florida. If I keep my hand on the stick for 5 minutes, it goes numb. Check the archives, this has been discussed many times. Jerry
Old Jan 25, 2019 | 01:13 PM
caskiguy's Avatar
caskiguy
Originally Posted by vettamunga
Hey gang
https://www.corvetteforum.com/forums...ss-report.html
Old Jan 25, 2019 | 01:20 PM
Bills17n72's Avatar
Bills17n72
what yr. corvette do you have?
Old Jan 25, 2019 | 01:54 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
What makes your hand go numb? By the way I'd recommend VA at this point too. I hear it cools much better.
Old Jan 26, 2019 | 09:41 PM
BLUE1972's Avatar
BLUE1972
I put VA in my 71 - works great.
If you shop you can get it for $1300 + free shipping
Old Jan 27, 2019 | 10:12 AM
Tampa Jerry
My hand goes numb from the 38 degree temp. out of the lower vents. Jerry
Old Jan 27, 2019 | 10:52 AM
bluegtp's Avatar
bluegtp
I have classic auto air I'm installing. Easy to connect and so far easy to install. Competent customer service is poor and documentation on wiring into a bi or trinary switch is poor. Controllers are bulky and control indications are cheesy. I'm comparing these to vintage air info and controllers I've seen.
Ryan
Old Jan 27, 2019 | 11:06 AM
20mercury's Avatar
20mercury
Default Ditto here too, agree!
Ditto here too, Agree VA is the way to go!
Old Jan 30, 2019 | 11:03 AM
vettamunga's Avatar
vettamunga
Cruising
Default C3 Vintage Air
Question to those that have installed a Vintage Air system on their C3: Will I need to remove the dashboard on a 79?
Old Jan 30, 2019 | 03:07 PM
20mercury's Avatar
20mercury
I am not sure if you can get Vintage Air for a 79 Corvette. See instructions available online:
https://www.vintageair.com/surefit-s...=GM%20Vehicles
And you might call VA to see what options you have.
Old Jan 31, 2019 | 08:57 PM
Pzark's Avatar
Pzark
I went with old air products for my 79, if it is just the A/C then if I remember correctly you may not need to remove the dash. Here are the parts that they suggested I needed from them
92-533. #6 90 deg fitting
92-525. #6 straight fitting
92-535 #10 90 deg fitting
92-535-4. #10 90 deg fitting S/P
92-534-3. #8 90 deg fitting S/P
92-526. #8 straight fitting
25-0046. Orifice tube
21-1230 Accumulator
11-1624 condenser superkool
4 feet 91-0010
4 feet 91-0008
5 feet 91-0006
Total parts cost is $668.30 plus shipping.
I replaced everything as my system was shot and I ditched the R4 compressor for a Sanden and changed over to R134. I also was told by my garage not to put the refrigerant in the system that you buy as a diy from auto stores because if it has that in the system they cannot sevice the A/C for me. So just sharing that with you. You may find this helpful
The larger hose port(the suction port), that goes straight to the accumulator on the firewall, calls for -10 hose & fittings WITH a service port. The smaller hose port(the pressure port), that goes forward to the top port of the condenser in front of the radiator, calls for -8 hose & fittings WITH a service port. The return hose coming back from the condenser, which goes to the other fitting sticking out of the firewall, calls for -6 hose & fittings WITHOUT a service port. A service port is where you introduce your 134a refrigerant, evacuate old freon, etc...which AeroQuip sells, & are incorporated into the hose end fittings.
The orifice tube will be inside the high-pressure line to the evaporator. Most orifice tube systems have the evaporator under the hood or cowl, Find where the line steps up in size just before a joint. The orifice tube should be in there
The fluid that passes around the whole system is the refrigerant. The refrigerant can evaporate at a low temperature, and then condense again at a higher pressure. In the bad old days, R-12 was the refrigerant used in almost all cars. It was widely available, however it was found to be a contributor to the hole in the earth's ozone layer as it was a chlorofluorocarbon (CFC). These refrigerants were discontinued, and all cars after 1996 use a non-CFC fluid called R-134A which is kinder to the environment.
Old Jan 31, 2019 | 09:46 PM
VERYSOON's Avatar
VERYSOON
R12 was "alleged" to be.
VS
Old Jan 31, 2019 | 10:00 PM
Big2Bird's Avatar
Big2Bird
I haven't done the Vintage air, but I would say you would have to. I would not try a heater core with the dash in, so, be prepared to buy a dash when you crack it.
Old Feb 3, 2020 | 08:32 PM
Boomer_54's Avatar
Boomer_54
Hi Blue1972,
Do you have a lead on a Vintage Air for $1300 and free shipping? I have a 71 and have to re-do the ac. My budget is squeezed b/c a lot of unfore-seen repairs an I need to shop smart.
Thanks.
Old Feb 4, 2020 | 10:10 AM
Stev-o's Avatar
Stev-o
This is the one I am looking at...
https://www.ebay.com/itm/VINTAGE-AIR...AAAOSwduxbKsHb
Old Feb 4, 2020 | 07:11 PM
Boomer_54's Avatar
Boomer_54
Thanks. I checked it out and it seems that's a distributor for Vintage Air. However, I live in a "tax' greedy state and the applied tax eats my cost savings
To C3 air conditioning
Old Feb 4, 2020 | 09:35 PM
Boomer_54's Avatar
Boomer_54
Default C3 Air Conditioning
I found a Vintage Air system at JEGS $1410.99 free shipping Part Number: 960-964173
https://www.jegs.com/i/Vintage-Air/960/964173/10002/-1
Old Feb 5, 2020 | 12:57 AM
l82vett's Avatar
l82vett
If you have existing AC , why can't you just change out the compressor , flush the system , hook it up and charge the system?
Old Feb 5, 2020 | 02:55 AM
Bikespace's Avatar
Bikespace
It looks like VA finally released their kit for 78-82 Vettes (there's a separate one for 77, too). $1500- at Jegs. Part 960-964176
https://www.jegs.com/i/Vintage-Air/960/964176/10002/-1
