I am looking for 6 of these in S/S, also 6 black neoprene washers. What are my chances someone has 'em, doesn't plan on using them, and wants to part with them?
Thank you
Reason: added a better detailed picture
@73ls1 Thank you, Charlie. I realize you sent these out to me. I really appreciate you doing that, unfortunately, and as we discussed in PMs, they never arrived. If they do arrive I will definitely let you know.
In the meantime, might someone have a set they kept after they tossed their rack? I purchased a ss rack from a forum member but I didn't know prior to purchase that the washers accompanying the rack were black plastic- no foul on the seller's part. I've been trying the DIY with ss washers from hardware stores, but the inner diameter of the washers are slightly too wide, and the sleeve doesn't cover it completely. I'm trying to keep the cost of this darn rack down before I go the parts house route.
^ ^ ^ ^ ^ I have 6 of those that came with the rack. The hole isn't wide enough to clear the wellnut head. I need rubber washers with larger holes. Thanks for the link.
