1978 Tail Light Ground Connector
Old Feb 11, 2019 | 01:46 PM
EP1978's Avatar
EP1978
Default 1978 Tail Light Ground Connector
My driver's side tail light has been acting odd lately, and I tracked it down to the ground. I need to replace the terminal/connector, but I have no idea what it's called.
Old Feb 12, 2019 | 11:00 AM
MelWff's Avatar
MelWff
that isnt part of the complete socket?
Old Feb 12, 2019 | 11:27 AM
Bikespace's Avatar
Bikespace
Mine did the same thing. I just replaced all 4 sockets, and spliced them together for 1968-style taillights. If one broke, you can bet they all will.
Old Feb 12, 2019 | 11:34 AM
EP1978's Avatar
EP1978
On the original socket, the ground wire has a sort of plunger connector, with this on the end of the wire. My socket is completely fine, with the exception of this little connector. I ordered replacement sockets from Willcox but they were Taiwanese and the prongs for the bulbs do not reach high enough to interact with the terminals on the bottom of the bulbs. Ideally, I'd like to replace just this ground terminal on each tail light since the other aspects of the original sockets are fine.
Old Feb 12, 2019 | 06:55 PM
Bikespace's Avatar
Bikespace
These are what I got. $8- at Zip:
https://www.zip-corvette.com/75-82-t...w-pigtail.html
Here's what happened to my old ones.
Old Feb 14, 2019 | 05:42 AM
EP1978's Avatar
EP1978
Same thing here. Looks like one of the many parts on these cars GM didn't intend to last 40 years.
Did the Zip sockets work well for you?
Old Feb 14, 2019 | 02:12 PM
C3_DH's Avatar
C3_DH
I have a brake light that won't work, going to get some new plugs. I'm also looking at that LED bulb.... I need some of those too.
Old Feb 14, 2019 | 04:03 PM
Bikespace's Avatar
Bikespace
They've worked fine so far. Here's taillights on, left turn signal on, LED 1157 bulbs in all four sockets. I want to say that I found the proper sockets with the original GM wiring colors, too, but I can't find them now.
To 1978 Tail Light Ground Connector
