Actual Ground Location??
Old Feb 12, 2019 | 11:12 AM
DaGuvner's Avatar
DaGuvner
Default Actual Ground Location??
1976 Vett.
I have replaced all my turn signal and side marker lights with LED bulbs as well as the turn signal flasher unit behind passenger dash pad and emergency flasher unit mounted directly to the fuse box. All lights work great with exception of the front left. I get parking lights but no flash for turning or emergency. I have researched the subject here and most recommendations indicate a bad ground.
My question:
Where is the physical ground located in the car?? I have a whole car wiring diagram which indicates several black wires converging at a common location. Where is it??
Thanks in advance :thumbs :
Old Feb 12, 2019 | 11:15 AM
TimAT's Avatar
TimAT
IIRC, the ground comes off the light and attaches to the core support.
Old Feb 12, 2019 | 11:21 AM
ntfday's Avatar
ntfday
Veteran: Marine Corps
The primary ground is where the negative battery cable attaches to the frame. That makes any metal that is attached directly to the frame a ground source. Clean the ground for the light in question and that should solve your problem. Good luck
Old Feb 12, 2019 | 11:43 AM
DaGuvner's Avatar
DaGuvner
Would that be on the left side of the core support??
Old Feb 12, 2019 | 12:06 PM
ntfday's Avatar
ntfday
I believe it is
Old Feb 13, 2019 | 12:17 PM
lakerider57's Avatar
lakerider57
I think you guys are talking about this ground:
Old Feb 13, 2019 | 02:53 PM
CraigH's Avatar
CraigH
On a 71 drivers side of radiator support.
Also an additional earth near horns on headlight support bar.
To Actual Ground Location??
