Blasting cabinet recommendations
Thanks!!
https://www.tptools.com/Most-Popular...-Cabinets.html
buying a decent used 80 gallon air compressor is going to be pricey. I found one on FB market place for $350 and had to clean the crap out of it, but it was worth it.Then all the plumbing and wiring was another $200.
Most are going to be around $500 or more
if i only run 1 at a time, it will run the entire time i blast unless i take a break and let it catch up and stop.
if I turn them both on, they will actually fill back up and shut off while im blasting
Definitely a rabbit trail of cost to do correctly...maybe I should just find a good local source to do the parts for me?
). Mine is the larger floor model, not the table top one. It has a connection on the side that I connect my shop vac to that helps keep the dust out of the air, and I still usually wear an N95 mask also (I use those for my woodworking dust also), I might investigate the Lowes gun that Slapjack9 mentioned, but the one that comes with it seems to work ok. It lists for $180 on their website, and you're probably aware that you can get 20-25% coupons fairly easily (sign up for their text messages via the website is an easy way to receive them).
https://www.harborfreight.com/abrasi...net-68893.html
Jegs has one that looks the same-
https://www.jegs.com/i/JEGS/555/81500/10002/-1
Yep- replaced the light- easy to do and with a LED there is no heat.
I replaced the gun- after the media blew a hole in it- 7 or so years of use
Built a wet dust reclaimer with a 5 gal tub -some PVC fittings - and a cheap shop vacuum
Running a 60gal 220V 7HP Cambell Hausfeld compressor that I got from Lowes- don't remember the price but it was a display model.
With the Harbor Freight Gun- it would just keep up- however the replacement gun (don't remember where it came from) but it doesn't use as much air and the compressor has no problems.
A set of ear muffs from Harbor Freight is also requirement !!!
As far as finishing the parts?
I sometimes paint them- and will toss the part in the oven for 30 minutes at 210 degrees-paint cures really nice.
I have the Harbor Freight powdercoater- works great IF you use media from Summit or simular quality. The HF powdercoat media sux-
Got a cheap digital toaster oven for less than $100
Here's my hood hardware- "kromezone" powdercoat
And thanks...great stuff!!
I doesn't smell like cookies though-my wife will come down to the basement as say " Oh, you have been baking!!!"
Use the same oven for powdercoating, a lot hotter at 400- there is no odor at all.
