Damaged Spindle
Old Feb 17, 2019 | 03:00 PM
BlueL82's Avatar
BlueL82
Default Damaged Spindle
I’ve attached some pick some of my spindle. It has nicks and scratches on the surface where the bearing presses on. Everything else is completely fine. Is this spindle safe to use?
Old Feb 17, 2019 | 04:00 PM
'75's Avatar
'75
As long as the bearings are still a press fit, I wouldn't be afraid to use it.
Old Feb 17, 2019 | 05:01 PM
BlueL82's Avatar
BlueL82
thats what I assumed. Thank you!
Old Feb 17, 2019 | 05:04 PM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
I've seen worst hold up fine.
Old Feb 26, 2019 | 05:35 PM
BlueL82's Avatar
BlueL82
I have found more damage when cleaning for paint. The base appears to be missing material. Is this safe? I’m worried about it being unbalanced. Should I get it machined?
This is my good spindle. The base is mostly even all the way around.
Old Feb 26, 2019 | 05:46 PM
'75's Avatar
'75
Looks like it was made that way, no issue that I can see and that is so close to the center of rotation that balance wont be an issue.
Old Feb 26, 2019 | 08:51 PM
GTR1999's Avatar
GTR1999
The marks are from someone burning off the old bearings and cutting into the spindle. The marks on the back of the flange shouldn't be an issue. I would mic the journals and see if they are undersize, if so they are no good anyway. I don't like the burn marks, they most likely will be ok but I don't think I would use them. I guess it all depends on what you want- an ok job or the best possible.
To Damaged Spindle
