1982 speedometer
Old Feb 18, 2019 | 10:31 AM
giese's Avatar
giese
1st Gear
Default 1982 speedometer
I own a 1982 Collector edition and the speedometer goes to 140, not 85mph. Anyone know why> Thanks. Mark
Old Feb 18, 2019 | 10:35 AM
kozmic's Avatar
kozmic
Perhaps try the C3 forum?
(https://www.corvetteforum.com/forums/c3-general-119/)
Old Feb 18, 2019 | 10:45 AM
roadbike56's Avatar
roadbike56
St. Jude Donor '16-'17,'22,'24
Need to get a Mod to move this.
Old Feb 18, 2019 | 11:06 AM
Atari_Prime's Avatar
Atari_Prime
A 1982 Corvette has a cross-fire injection system with 200 HP. I don't recall the specifics of the transmission, however the 1982 Corvette and 1984 Corvette have very similar drivetrains. If you look up some older Motor Trends you should find that the top speed of the 1982 Corvette to be somewhere between 130 and 145, therefore a 140 speedo sounds about right.
Old Feb 18, 2019 | 11:07 AM
Dominic Sorresso's Avatar
Dominic Sorresso
May very well be a Canadian build using km rather than mph.
Old Feb 18, 2019 | 12:26 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
It's been changed. Mine had the same when I bought it used. Look at your crossed flag emblem in the speedo. All 82's had the 85 speedo.
Old Feb 18, 2019 | 12:39 PM
RJ-92's Avatar
RJ-92
St. Jude Donor '26
Not unique to Corvette. I believe it was int he late 70 the gov't mandated or at a min suggested that Spedo's only go to 85 MPH as to not encourage excessive speeding. That went away in the med 80s
Old Feb 18, 2019 | 01:59 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Tally Ho
...It's been changed...
Yep. Aftermarket speedo face.
Old Feb 18, 2019 | 03:04 PM
L-46man's Avatar
L-46man
I too have a 82 CE....the speedo/ face has been changed and probably the speedo gear in the tranny. GOOD FOR YOU! REJOICE! I'm reduced to doing math on the fly.... 36mph/1000 rpm.
BTW an 82 CE IS A C-3 for those who are reading challenged....it's the LAST of the C-3's
Unka Hal
.70 4th gear locked up and 2.87 rear with 255/60/15 tires and you get the above.
Unkahal how fast are you going? 3000 rpm! LOL
Old Dec 3, 2019 | 07:44 PM
C3Highway's Avatar
C3Highway
A previous owner almost certainly changed your speedo out for the 140mph face you have installed now.
From about 1974-1987, the maximum speed limit all across America was set at 55mph, mandated by federal law. Today, that probably seems hard to believe for some.
Adding insult to injury, a federal regulation, effective 1 Sept 1979, required all domestic vehicles, including the 1980-1982 Corvettes, to be fitted with speedometers that read to a maximum of 85mph—with 55mph highlighted—which was orange for the Corvette.
That regulation only lasted about two years before it was repealed. Federally mandated speed limits were fully repealed by 1995, returning that authority back to the states.
The 85mph speedometer began being installed on very late 1979 Corvettes, and ran through the end of C3 production.
Old Dec 4, 2019 | 02:07 PM
7T1vette's Avatar
7T1vette
You have to do more than just change the face plate. The gearing inside the speedo needs to be changed OR the electronics that drive the speedo must be altered to account for the gearing offset. Normally, this is just a full speedo unit change-out.
Old Dec 4, 2019 | 08:34 PM
C3Highway's Avatar
C3Highway
The original poster didn’t mention any issue with speedo accuracy, but to the relevant point made by 7T1vette, it is true that some folks just change the face to 140mph and leave the speedometer unit itself unconverted. I would think that would cause indicated speed to be about twice actual vehicle speed.
One option is to have a vendor perform a conversion service on the 85mph speedo unit, which should include the new 140mph face.
I think all this might risk an NCRS deduction.
Old Dec 5, 2019 | 12:29 AM
7T1vette's Avatar
7T1vette
Ahhh....but there would be LESS deduction for a speedo with merely a replaced face plate! IT would still have the original factory internals!!!!
Old Dec 5, 2019 | 03:46 AM
Bikespace's Avatar
Bikespace
Did someone say 1982?
At 5:35 in this excellent review, there's a shot of the 85 mph speedometer.
Why would someone change the face when you can buy a complete speedo/tach/lights cluster unit on eBay for less than $100-?
To 1982 speedometer
