Help to identify 4-speed shifter
Received 1,308 Likes
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
I have a 4-speed shifter that was used in a '75 I owned (until I changed to a Hurst) that bears the number 392184. I don't have an AIM or any books to research, and Google uncovered nothing. I am looking to put it up f/s but I would first like to be able to confirm the years it can be used.
I have the rods and mounting bracket if that would help identifying this piece. Thank you
Last edited by cor66vette; 03-12-2019 at 01:47 PM. Reason: added comment about rods and mounting bracket
cor66vette (03-15-2019)
My parts book only went to 72' and it had a different part number than the one you have. I would suspect that it fits all the BW T-10's and the older one in my parts book was for the Muncie. Someone will have a later parts book. It looks just like the one in my 79'
My Corvette parts book goes to 81. For the 4-Speed, it shows 3921638 as the 68-76 lever. 378185 as the 77-81 lever. Yours looks like 3921840 to me.
Perhaps that isn't from a Corvette?
As far as I know, the Corvette was the only GM car with the "t-handle" reverse lockout feature. My understanding was that it prevented inadvertent shifts to reverse, when the car was being road raced, and not too many other GM muscle cars were road raced.....street raced, yeah, but that involved mostly upshifting, only.
It definitely is the "lever", right, not some other part, and not part of a 3-speed shifter?
If that 8 is actually a 6, and the "0" digit is a 2 that has been ground down...
3921642, 68-76 Y body (Corvette), HANDLE, Cont Rev Rel
Maybe that's it? CONTrol REVerse RELease perhaps? I can easily convince myself that it is 392164(something). My 80 came with a Hurst, so I have nothing to directly compare it to.
Here's an image of the relevant section of 4-speed manual transmission parts.
Yes, the numbers appear at the base of the lever and it's a 4- speed.
I'll consider it a '68-'76 shifter. I don't have the '75 any longer but I still have a '68. If it will fit the '68 I'll not put it up f/s and just hold on to it.
Thanks for looking into this.
60's Chevelle, Nova, Impala. While looking around for an answer to your post I found this that was interesting , fwiw:
https://www.corvetteforum.com/forums...ter-mount.html
Here is a 66 Chevelle
