68-72 4-speed shifter mount
Old Oct 5, 2009 | 09:06 PM
Razzle's Avatar
Razzle
Default 68-72 4-speed shifter mount
Does anyone have a picture? A friend says it mounts to the x-member, and i say the trans. Anyone? Thank you
Old Oct 5, 2009 | 09:10 PM
...Roger...'s Avatar
...Roger...
Mounts to cross member. 65 was the last to mount to trans
Old Oct 5, 2009 | 09:14 PM
GD70's Avatar
GD70
If it's a Hurst, It mounts to the tranny.
Old Oct 5, 2009 | 09:15 PM
Gordonm's Avatar
Gordonm
Crossmember. That is why they had problems. The motor and trans would twist a little during hard acceleration and the rods would bind up. The Hurst shifter bolted to the trans and was a much better shifter.
Razzle's Avatar
Razzle
Wow, that seems backwards. The 1st camaro/Chevelle 4-speed shifters were on the x-member too. But, when the motor/trans would flex on the rubber motor mnts, the x-member mntd shifter wouldn't go along for the ride and would bind up. So, they mntd the shifter to the trans. Seems they had the "right' idea on Vettes and went to the wrong idea. Makes no sense. Thank you (anyone else wanna weigh in? with a pic?)
Old Oct 5, 2009 | 09:21 PM
...Roger...
I think Duke94 had some good pics of the mount but I wasn't able to find them.
Old Oct 6, 2009 | 06:30 PM
Alan 71's Avatar
Alan 71
Hi R,
If you look carefully in these 2 pictures you can just see the black mounting bracket to the right side of the shifter body.
GM do something BACKWARD!!! NEVER!!!
Regards,
Alan
Old Oct 7, 2009 | 01:05 PM
Razzle's Avatar
Razzle
Originally Posted by Alan 71
Hi R,
Regards,
Alan
So, does the black brkt. go to the x-member/chassis?
Old Oct 7, 2009 | 01:52 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
The vertical shifter mounting bracket mounts to the horizontal transmission mount support bracket...one end of which attaches to the transmission mount and the other end to the cross member.
Old Oct 8, 2009 | 12:52 AM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Razzle: dug out my stuff and found this. Hope they help explain the images Alan 71 provided:
If you need different angles than these, lemme know. Good Luck.
Old Oct 8, 2009 | 08:14 AM
Razzle's Avatar
Razzle
Great pictures. Thank you so much
Old Oct 8, 2009 | 11:58 PM
Solid LT1's Avatar
Solid LT1
GM did it to isolate the shifter and keep cruising vibrations down, obviously someone who never power shifted a solid lifter Vette at redline wanted this change in 1966.
Old Oct 9, 2009 | 10:13 AM
Razzle's Avatar
Razzle
Exactly
Old Oct 9, 2009 | 06:18 PM
Alan 71's Avatar
Alan 71
Hi S LT1,
Are you implying that some Corvette owners didn't shift their transmissions in the proper manner and at the proper rpm?
I never heard of such a thing!
Regards,
Alan
Old Nov 12, 2012 | 11:42 AM
MarkHarclerode's Avatar
MarkHarclerode
Default 4 Spped Bracket Mounting Bolts on the Cross Member
I have a 1969 4 speed that currently has a Hurst, but I am restoring it to original Shifter (Crazy???).. I bought a complete shifter, bracket and rods that came out of a 1969.
I looked at the mounting holes on the rear side of the Cross member where the bracket mounts and it appears that the cross member has 2 5/16 inch tapped holes for rear of the 4 speed shifter bracket. The picture in this thread shows bolts and nuts to hold the back end of the bracket.
The bracket I purchased has mounting holes that look like 3/8 inches where it attaches to the cross member.
Did the 1969 Bracket have smaller holes or did someone just drilled out the tapped holes on the frame.
Just curious and would like to keep it original.. Thanks
Old Nov 12, 2012 | 04:47 PM
MelWff's Avatar
MelWff
same bracket 68 to 79
https://www.paragoncorvette.com/p-35...g-bracket.aspx
Old Nov 12, 2012 | 06:16 PM
ezobens's Avatar
ezobens
Absolutely!
The OEM shifter is crap.. My condolences..
To 68-72 4-speed shifter mount
