side pipe ID question
Old Mar 16, 2019 | 05:33 PM
Lyndwood's Avatar
Lyndwood
Default side pipe ID question
I bought my '74 with the chrome side pipes (aftermarket) and headers already on the car. the headers are discolored but in good condition. the side pipes have pin holes and some rot holes on the bottom of the tubes so I want to replace them,. my question is how do I know who's make header it is so I can buy a replacement side pipe. I don't see the normal "hooker" badge on the header nor do I see any other stamping's. I see you can buy Hooker and Dougs replacement side pipe tubes, are they all the same? I just don't want to buy one that either wont bolt up or my muffler inserts don't slide into. Is there any way to tell the side tubes apart, I figured someone else on here must have come across this dilemma once or twice?
Paul
Old Mar 17, 2019 | 01:27 AM
Bikespace's Avatar
Bikespace
No answers? I believe the side pipes are basically the same. There may be 3 1/2" versions around, but most likely you have 4" pipes. The inserts are almost certainly all interchangeable, so the pipes should be as well.
For my Craigslist headers, the PO bought a set of 4" diesel truck smoke stacks. Whatever fits I s'pose.
Check with Jegs or Summit or wherever first to see if they accept returns on these items (even when they fit, they won't be "new" after you test fit them). Or buy them from Amazon (or Costco!), who never seem to question returns.
Old Mar 17, 2019 | 11:53 AM
MelWff's Avatar
MelWff
My experience was when inserting a Dougs muffler into a Hooker side pipe the fit was extremely tight, I dont think the mufflers will ever come out. So there may be a slight fractional variation in dimensions.
To side pipe ID question
By Michael S. Palmer | 2026-06-03 09:39:05
