Speedo quit working
Old Mar 25, 2019 | 10:32 PM
RonnyV1980's Avatar
RonnyV1980
Default Speedo quit working
With the weather getting better, it is time to start getting a few things sorted out. First on my list is getting my speedo working. This is what it did before finally quitting. The needle was pretty bouncy until it got to around 80 kmh, then it steadied out. Then it just quit. When I got into it before winter, it turned out that the cruise control unit was all locked up. Replaced the cruise, but still no movement on the speedo needle. I put the drill on the end of the speedo cable where it goes into the trans and the speedo works fine and you can hold any speed you want. I'm open to any suggestions on where to go next. I don't think I will be so lucky as to just replace the speedo cable. Is it a big job to replace the gear that the cable goes into? I am wondering if the gear got messed up when the cruise unit locked up. Any ideas?
Old Mar 26, 2019 | 07:53 AM
slapjack9's Avatar
slapjack9
Although I've never had to replace the gear in the transmission I would bet that's your problem.
Old Mar 26, 2019 | 08:37 PM
RonnyV1980's Avatar
RonnyV1980
If we go with the theory that I am going to have to replace the plastic gear on the side of the trans to make the speedo work, has anyone done this? There are plenty of videos on utube but most of these have the trans out on a bench in a shop. Has anyone done one of these gear swaps in a C3 auto still in the car? In nearly all of the vids I have watched they get tranny fluid all over the place and I am not prepared for that.
Old Mar 29, 2019 | 10:52 AM
DB Cooper's Avatar
DB Cooper
I have. My car has been swapped to a 700R4 trans, but I wouldn't imagine the stock trans is a lot different. Jack up the rear of the car, and set stands in place (even if you can reach in there withiut jacking it up, this will help minimize tranny fluid drip). Unscrew the cable, pull the retaining bolt, and slide the driven gear assembly out. Easy peasy. Simple enough that it's a good idea to pull it and inspect it before assuming it's bad. Plus if you have to replace it, you'll want to count the teeth to be sure about the replacement anyway.
Was your speedo accurate when it was working? If you end up replacing the gear, you can go up or down a tooth to dial it in better.
Old Mar 29, 2019 | 03:26 PM
Bills17n72's Avatar
Bills17n72
I was told that every tooth will change it 5mph.
To Speedo quit working
