Composite rear spring
Old Apr 3, 2019 | 07:34 PM
1BADL82's Avatar
1BADL82
Default Composite rear spring
I installed a composite rear spring on my 79 the problem is the bottom of the spring is at the middle of the tire, I know it should be above the rim, I don't have a spacer on it or is it just the wrong spring?
Old Apr 3, 2019 | 08:45 PM
Mooser's Avatar
Mooser
Some of the TRW springs have quite a high arch on them and there have been lots of complaints of the cars sitting way to high. Others seem to sit at stock height (I have one and it's pretty much the same as the steel spring was)
You can run a longer bolt to help lower the car (8 is normal but people have run 10)
Lowers the car but doesn't have a lot of affect on where the spring is compared to the tire.
The fear is if you get a flat the spring/bolt can hit the ground
What spring do you have?
M
Old Apr 7, 2019 | 01:49 PM
1BADL82's Avatar
1BADL82
It is a Van Steel Hyperco 330 Lbs. I have the long bolts on it now it sits perfect just do not like it being that low
Old Apr 7, 2019 | 06:26 PM
Mooser's Avatar
Mooser
8" or 10" bolts?
M
Old Apr 8, 2019 | 09:07 AM
Bikespace's Avatar
Bikespace
Give them a call. I believe Van Steel also sells the low arch springs. You may be able to swap.
Old Apr 8, 2019 | 08:47 PM
1BADL82's Avatar
1BADL82
They are 10 in bolts
Old Apr 8, 2019 | 08:48 PM
1BADL82's Avatar
1BADL82
I will look into that
thx
Old Apr 8, 2019 | 08:57 PM
Mooser's Avatar
Mooser
That sounds like one of the higher arch (TRW style) springs then, nothing you can do other than go to a 8" bolt (brings it to rim height) and have about a 27-1/2" height at the top of the wheel arch (IIRC, could be wrong...)
or switch to a low arch spring as suggested above
M
Old Apr 8, 2019 | 09:58 PM
1BADL82's Avatar
1BADL82
Im at 27 1/2 now to the wheel arch, I will be getting a low arch spring
Thx for the info
Old Apr 8, 2019 | 10:45 PM
Bikespace's Avatar
Bikespace
Thx for the info
I'm glad it will work out for you! Please post a before and after image if you can. Illustrative examples on the Forum can help out others, including the silent majority who read the Forum but never post.
Old Apr 10, 2019 | 08:05 PM
1BADL82's Avatar
1BADL82
Who else sells a composite spring? How do you know it is a low arch spring?
To Composite rear spring
