Removable rear window
Old Apr 6, 2019 | 09:38 PM
OBX C3's Avatar
OBX C3
Default Removable rear window
So at some point in the past some installed a removable rear window , and today I install a new rubber weather stripping. I had a hell of a time getting the window in after the rubber was installed . I readjusted the latches and it was a very tight fit . I finally got it .
Is this normally this hard ?
Old Apr 6, 2019 | 10:24 PM
Mooser's Avatar
Mooser
Mine was stiff enough I had to loosen the bottom receivers as well as the latches and then partly latch it for a day or so before everything settled in a little, then I re-adjusted and it goes fine but pretty tight. It'll work a little better after it's in a few times and it's hotter out.
The new rubber is tends to be a lot stiffer than the original ever was
M
Old Apr 6, 2019 | 11:23 PM
JoeMinnesota's Avatar
JoeMinnesota
On my '70 it's all original and still pretty tough getting the latches clamped in place. They do fit tight.
Old Apr 7, 2019 | 09:27 AM
OBX C3's Avatar
OBX C3
Thanks for the replies.
To Removable rear window
