Love that fuel injection setup, who makes that intake manifold?
Custom made by Bruce at FB Throttle Bodies. Basically an Edelbrock Dual Quad welded up and remachined for the new throttle bodies and injector bungs added. We probably could have squeezed one based on the Air-Gap Dual Quad under the hood but this was safer.
A single plane probably would have worked better with the EFI but this has a little more bling.
Thank you Steve for the info, I bought the QED 1050 dominator for my 540, after I seen your setup,I'm having second thoughts.
The Dominator will make more power. I ran carb tripower to fit under the stock hood. Used the Mopar mechanical secondary carbs and it was a beast. The EFI is much more driveable, maybe a bit down on power. A normal 4bbl EFI would probably make more power but this setup is visually appealing.
