Full Throttle Restored
Old May 4, 2019 | 02:50 PM
C3 Stroker's Avatar
C3 Stroker
Default Full Throttle Restored
After dealing with less than full throttle on my '69 once again, I changed my pedal assembly from the early style 68-69 two piece rod deal to the later style 69-82 solid rod style. But before I bolted it in, I slightly bent the upper part of the rod (using a vise) inward 3/4". This is because Holley style large cfm carbs need a longer arc for full cable throttle, and that bend fixes that difference.
No more of this.....
It is now like this diagram..........(thanks, Willcox)
