Engine wiring harness
Old May 18, 2019 | 11:50 AM
Jim71Vette's Avatar
Jim71Vette
Default Engine wiring harness
I'm installing a new harness on my 71. The connector for the transmission kick down passes through a grommet on the firewall along with the oil pressurei line in the same hole. Now I can't see assembly line workers taking the connector apart, passing the wires thru the grommet and reassemble the connector and attach to the kd switch. I'm thinking of cutting a slot in the grommet, insert the wires and oil line and then insert the grommet. Is this how is was done on the line? Is there a better way to do this?
Old May 18, 2019 | 04:41 PM
sullyman56's Avatar
sullyman56
I believe that cutting the grommet is the way it was done. I replaced my speedo and tach cable and ended up cutting both grommets. It made it a lot easier since on my 68 the cables screw on the back of the tach and speedo.
Old May 18, 2019 | 10:02 PM
Jim71Vette's Avatar
Jim71Vette
Thanks Sully... I think that's the best way to go.
Old May 18, 2019 | 10:37 PM
Al.'s Avatar
Al.
Yes same.
I cut slit
Old May 19, 2019 | 08:06 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
all of mine had slits, not sure if they were from the factory but they appeared to be. A little WD on the rubber will help you to get the grommet back in he firewall if its a tight fit
Old May 19, 2019 | 08:20 AM
CaseyP's Avatar
CaseyP
Cruising
I worked at the GM division (Packard Electric Division) that made this harness. The wires were placed in a mold die in an injection molding machine and the rubber grommet compound was formed and cured around the wires. Slitting the grommet and then using sealant when you are done is the only practical way to service this.
Old May 19, 2019 | 08:53 PM
crf311's Avatar
crf311
The grommet I purchased had slots cut for each item which passed through it.
Old May 20, 2019 | 11:26 AM
Jim71Vette's Avatar
Jim71Vette
Thanks to all... I used a hacksaw blade to slit 2 holes and a little dish soap to aid getting the grommet back in ... done.
To Engine wiring harness
