Once again - 73 chrome front bumper
Old May 25, 2019 | 05:35 AM
emccomas's Avatar
emccomas
Default Once again - 73 chrome front bumper
I ran across this 1973 Corvette coupe for sale in south Alabama, near Mobile.
Owner installed a fiberglass replacement front bumper cover and modified it to accept a 68-72 front bumper.
This is the way it think it should be done. I like it.
Old May 25, 2019 | 08:53 AM
derekderek's Avatar
derekderek
missing bumperettes and chrome around grilles, but not a bad job at all. you have probably seen this thread. https://www.corvetteforum.com/forums...nt-bumper.html
Old May 25, 2019 | 09:43 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
WARNING: DO NOT TRY THIS AT HOME (lol)
This mod is not done to "Trick" anyone,,,,it is done to eliminate buying a new clip by using the existing "nose" since the '73+ cars are shaped differently than the '68-'72 cars. (Plus....I'm a rookie who learned from great Forum Members)
A chrome bumper can be re-arched at the corner bends to fit well on a '76 front clip (which I inherited on my basket-case project).
Make a wooden pattern of the fiberglass area on the car where the chrome bumper will fit against.
"Warm" the chrome bumper from the back-side with a hand-held propane torch....
then use a vice with wooden slats place on the steel jaws to prevent damaging the chrome bumper....
gently clamp the "short end" of the bumper in the vice and use the rest of the bumper for leverage....
slowly heat and apply slow body-force to the bumper until it "moves" to fit the pattern.
Once the "new fiberglass bumper lip" is bonded into place there will be about 5/16" clearance between chrome bumper and fender....
(I did not HAVE to fit a reinforcement lip into the fender,,,,I did so for support and a "factory look".
With patience you can get a very good fit/clearance to the car without ruining the chrome on the bumper.
Initial bend/modification shown below....final bend/tweak will be done once the "lip" is bonded into place...….
Old May 25, 2019 | 12:42 PM
derekderek's Avatar
derekderek
The bumper lip. Doorgunner alluded to it, but his hand and bumper is hiding it. This is a generic pic but it shows the bumper lip pretty well. https://www.google.com/search?q=c3+f...b6RSa7jBYO_k4M. It can be fabbed on to the front bumper that you're customizing into a Chrome bumper replacement. But, do you want to do the same with the fenders which would actually alter the clip? I had a thought for a Bubbaesque mod. Get something flexible that you can paint the color of the car. You need a piece about 1" by 4". Maybe 2" by 4". Paint it to match the car and attach it to the side lip of the top of the front bumper. So that it fills the space that otherwise you would see daylight through where the lip is not there.
Old May 25, 2019 | 01:07 PM
emccomas's Avatar
emccomas
I think they are "missing" on purpose, and really should not be there on a 73 car, but TMHO.
I would like to see the ends of the bumper reworked so they better fit the car, and another thing that I have always thought is that the edges of the bumper that stick up / down at the center of the V should be reworked so they are flatter.
Still, all in all, it is a credible job.
Old May 25, 2019 | 01:17 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
My 73 has a replacement, fiberglass nose too, but not the one adapted to accept the chrome bumper. While I prefer the long, seamless nose, I think the above looks really good. Works very well with the 73 grills, particularly with the silver leading edges.
Old May 25, 2019 | 07:38 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
I owned a ‘73 L82 in the 70’s. I loved that car and would have liked it even more with the chrome bumpers.
Old May 25, 2019 | 09:03 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
meh... I say leave the 73's be! They are a single year body and have their own uniqueness to them. If you want a 68-72 car, buy one of those. I say this of course being the proud owner of a 73.
Old May 26, 2019 | 09:16 AM
derekderek's Avatar
derekderek
A 68-72 car in the same cond as a 74-77 car is nearly twice as expensive. You find a 75 that is decent but ugly and can do this type of work...
Old May 26, 2019 | 10:39 AM
doorgunner's Avatar
doorgunner
True...I wouldn't modify any original C3, '73 unless I could customize an aftermarket bolt-on "nose-chrome bumper", and save the original "nose-rubber bumper" assembly.
. I modified mine because it was a Basketcase too far gone bodywise.
To Once again - 73 chrome front bumper
