Door ajar/Alarm switch
Old May 29, 2019 | 11:13 AM
crjones40's Avatar
crjones40
Cruising
Default Door ajar/Alarm switch
I have been working on the alarm for my 72 Vette. The alarm appears to work as with the key lock on the passenger open the horn will honk (although a weak horn and probably needs replaced). My driver door open the alarm did not sound. Discovered the switch was bad so I ordered a new switch. Got to the switch wiring through the access panel. Cut off old connectors on the blue, white and black wires and installed new connectors. When inserting the connectors into the new switch doe it matter which slot they go in?
Old May 29, 2019 | 11:16 AM
BarryB72's Avatar
BarryB72
This is rear door jamb switch right?
I've had mine apart a couple times. I don't think it matters as long as all 3 connectors make contact when you depress the switch - sorry, when the switch is not depressed.
Old May 29, 2019 | 01:45 PM
crjones40's Avatar
crjones40
Cruising
Default Door alarm/adjar switch
Thank you for the reply. I didn't think there was any certain slot but I wanted to verify. Also the connectors have a hook at the end to hold the wires in place. Which way should the hook go? Facing in or facing out?
It is the switch located on back of the door jamb. I used my test light and with alarm key on it has power to the blue wire. With the alarm of and the ignition on there is power to the white wire which should be the door ajar.
Last edited by crjones40; May 29, 2019 at 02:11 PM. Reason: Just wanted to add additiional information
Old May 29, 2019 | 02:30 PM
BarryB72's Avatar
BarryB72
I think my hooks face inward.
Old May 30, 2019 | 07:37 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
use an air compressor and blow out the horn from the mouth.They can get full of dirt and bugs.
Old May 30, 2019 | 09:23 PM
crjones40's Avatar
crjones40
Cruising
Thanks for all of the responses. Alarm horn does not work so I need to replacement horn and it appears that no one is making a replica horn. For those of you who replaced the factory alarm horn what horn do you recommend as a replacement.
Old May 30, 2019 | 10:46 PM
BarryB72's Avatar
BarryB72
Why not send it out to get restored?
I used a place in Beloit Wisconsin that makes sure your "horn works".
Old May 30, 2019 | 11:12 PM
crjones40's Avatar
crjones40
Cruising
I was was not aware there was such a place that did that. What is the name of the business?
Old May 31, 2019 | 12:15 AM
BarryB72's Avatar
BarryB72
The Horn Works
To Door ajar/Alarm switch
