Side mirrors
Old May 31, 2019 | 03:43 PM
Vandy2018's Avatar
Vandy2018
Default Side mirrors
Has anybody had a problem with their side rear view mirror being blown out of position at highway speed.
This is happening on my 68. Is this just my mirror
and should I buy a new one? Or a design flaw and expect this to happen with a new one as well.
Old May 31, 2019 | 10:42 PM
Eliredandblack's Avatar
Eliredandblack
this is very common on both driver and passenger side mirrors. There are number of posts that will give you step by step instructions to repair the tension on the ball socket. It’s probably easier to Google Corvette rear mirrors drooping. I had to fix mine twice because, the first time I didn’t make the “friction bar” tight enough. Pretty easy fix.
Old May 31, 2019 | 11:20 PM
Dirty Dalton's Avatar
Dirty Dalton
I've had good results using GREEN Loctite. Aim the mirror towards the ground, dribble in the Loctite, and set the mirror where you want it. Have something under the mirror to catch any drips.
Not a suitable fix if you like to play with your mirror. 😉
Old Jun 1, 2019 | 07:59 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
LOL I just did the loctite trick last night but i used blue. I hope it works.
Old Jun 1, 2019 | 04:39 PM
bigdaddy33's Avatar
bigdaddy33
Same thing on my '70. Seems it's a very common problem. The swivels are worn. You can try the different "fixes" (results seemed to be mixed), but I decided to just replace them both with new mirrors. Problem solved. Look and work great.
Old Jun 1, 2019 | 05:17 PM
C3 Stroker's Avatar
C3 Stroker
Since I've had my '69, I've replaced the side mirror about 3 times over 20 years. I've done the mirror fix once, and it lasted a long time but eventually wears off. Just replaced it again last year. The new mirror I got from Zip Corvette is tighter than any I've had in the past.....if fact, very tight. Glad they are being made tighter. Perhaps I'll never have to buy another one.
Old Jun 1, 2019 | 05:44 PM
Rescue Rogers
I'm putting a new one on my wish list
Old Jun 4, 2019 | 09:20 PM
kdf1986's Avatar
kdf1986
I have the same problem with my 73. I solved it by turning the mirrors upside down ( 180 degrees). They seem to hold good at that position.
kdf
Old Jun 4, 2019 | 09:27 PM
BLUE1972's Avatar
BLUE1972
I used thick Crazy Glue, just put rags under the mirror to protect the paint. Next morning 0 good to go..
Align the mirrors first they will stay in that position for years... .
Old Jun 4, 2019 | 09:34 PM
gjohnson's Avatar
gjohnson
Super glue for me
Old Jun 5, 2019 | 11:21 AM
Rescue Rogers
Thiscweekend i tok a center punch and punched along the ball at all extremes, then the mirror fell out, so i was able to use red locktight on the ball from the inside. Its not moving now
To Side mirrors
