I converted over to 134a from R12 by installing the eliminator kit and after fixing a couple of pin hole leaks I now can pull and hold 28/29hg for 2 plus hours..
The problem is when I try to add the 134a refrigerant, it will not go into the system, I even jumped the contacts on the compressor so that the clutch was engaged and it still would not flow into the ac system. Any suggestions on what I may be doing wrong. It has an A6 compressor..
Yes...You have a schrader valve mis-alignment problem. The adapter has a schrader valve in it and so doe your can-tapper....one or the other is not pushing open.
