Seat Belt Recommendations?
Old Jun 14, 2019 | 12:39 PM
AdamMeh's Avatar
AdamMeh
Default Seat Belt Recommendations?
We need new belts in our '77. Any recommendations on some quality belts that won't break the bank? We do want a set with shoulder harness (stock replacement type). This is not a NCRS type build, so I don't need the GM logo etc.
Thanks,
Adam
Old Jun 14, 2019 | 01:17 PM
AdamMeh's Avatar
AdamMeh
Originally Posted by SMF
I had Seatbelt Solutions in Jupiter Florida do one for me when the retractor locked up and I needed a replacement. They did a great job, matched my original belts perfectly, and didn't hurt that their location was close by for me. Ask for Eric Dellinger, the operations manager or Jonathan Lloyd, they will treat you right. Here's the link. https://www.seatbeltsolutions.com/corvette
Thanks SMF - I'll check them out!
Old Jun 15, 2019 | 09:23 AM
Street Rat's Avatar
Street Rat
Thanks,
Adam
I got mine from these folks Adam....http://www.ssnake-oyl.com/
Craig
Old Jun 15, 2019 | 12:36 PM
AdamMeh's Avatar
AdamMeh
Craig
Hey Street Rat - Thanks for the head up. I hadn't heard of this company. How was the fit / finish when installed?
Old Jun 15, 2019 | 01:37 PM
Duke94's Avatar
Duke94
Craig
Me too. Did a good job.
Old Jun 15, 2019 | 01:56 PM
AdamMeh's Avatar
AdamMeh
Hey Duke - did you have them rebuild your belts or purchase new from them? I'm looking for new belts due to changing the interior color.
Old Jun 15, 2019 | 02:44 PM
Duke94's Avatar
Duke94
I had them rebuild my stock belts. They'll use whatever color webbing you want. Doesn't have to be the original color.
Old Jun 15, 2019 | 02:58 PM
Street Rat's Avatar
Street Rat
Yes they did an exceptional job. I purchased a factory type replacement kit. Not expecting anything fancy, I was quite surprised at the attention to detail.
Craig
Old Jun 15, 2019 | 05:48 PM
AdamMeh's Avatar
AdamMeh
Nice... I hadn't thought of going that route, but it sounds great. Thanks Duke.
Craig
Thanks for the feedback SR - Much rather find someone through word of mouth than go in blind. Appreciate it.
Old Jun 15, 2019 | 06:31 PM
CanadaGrant's Avatar
CanadaGrant
Hi Adam. I also bought a set of one piece lap/shoulder belts from S Oil for my 69. The stock ones were fine but my wife complained about having to do up the lap belt, then try and attach the shoulder belt, then have the shoulder belt belt come off if you looked at it wrong.
They were cheap, look great and flat out work with no modifications at all. I still have the original in a box but these were well worth the money.
Old Jun 15, 2019 | 06:52 PM
AdamMeh's Avatar
AdamMeh
Wow - they look even better than I thought they would. Is this what you purchased? http://www.ssnake-oyl.com/mm5/mercha...ory_Code=3PRLS
Old Jun 15, 2019 | 06:58 PM
orourke's Avatar
orourke
Heres another option. https://www.seatbeltsplus.com/catego...eat-belts.html I just bought the rollbar shoulder harness set for my 1967 GT-500. The only company that reproduces them. I'm very happy with the belts. They look OEM.
Old Jun 15, 2019 | 07:27 PM
AdamMeh's Avatar
AdamMeh
Thanks Orourke - I have looked through their site, and was leaning towards their belts until I saw the prices on the one mentioned above. I appreciate the help.
Adam
Old Jun 15, 2019 | 09:05 PM
CanadaGrant
When I purchased them it was about 5 years ago. They didn't have the red logo on the belt like on the page you posted and look sort of stock if you didn't know that a 69 had two piece seat belts. They actually had a clip on the front of the seat bottom to keep them from dragging around on the floor and the shoulder strap would just pop right off if you moved. Kind of worthless. Those aftermarket belts bolt up to the stock location and even though they are not correct, they work, are cheap, and you don't have to make any modifications to bolt them in. Your biggest deal is making sure the original belt bolts on the floor pans are soaked in WD40 or whatever for a couple of days just in case they don't want to come out. Seized seat belt bolts is (are?) pretty common...
Old Jun 15, 2019 | 09:55 PM
DavidandJoansVette's Avatar
DavidandJoansVette
Veteran: National Guard
I also used seatbeltsplus. Unfortunately my grandson wrecked his car before I gave them to him. Returned for a refund with no problem. Would use them again,
Old Jun 16, 2019 | 08:25 AM
palmbeachvette76's Avatar
palmbeachvette76
Adam i'm Eric mentioned in the thread as the one at Seatbelt solutions, I left the company over a year ago but I would go with the economy line (link below to Seatbelts Plus) for $189 they are a direct bolt in application for your car without the factory matched webbing material and GM logo buckles as you stated wasn't something you needed. They don't come with the sleeve that holds the buckle up but if you have yours you can reuse them provided they are in good shape if not order them separate.
https://www.seatbeltsplus.com/produc...477D-Dual.html
To Seat Belt Recommendations?
