Opinions needed
Note the engine to the left of this post. Does that look like an engine that would enjoy being over 200 degrees?
Hell no! It prefers 160-180. And the owner prefers that also.
For a engine that came stock with a 195deg thermostat it is never reaching normal temp if it never gets past 170.
Its apples and oranges to compare your motor to a low compression factory motor. I just don't think 160-170 is hot enough to really drive moisture out of the oil. From what Ive observed on a stock engines with an oil temp gauges is that the oil temp is just slightly above water temp at low load. So just puttering around with a 165 water temp the oil might only be at 175.
Water boils at 212. So in my street car I would shoot for 195deg water temp to get the oil temp just over 212 to boil the moisture out.
I don't think I am alone in this line of thinking. Go see what the GM engineers picked even before the "smog" times. 1968 327 OE temp: 195F. 1968 427 OE temp: 195F
If we where not talking about a street car and this was a modified high compression motor where detonation is the biggest worry above all else then that would be a totally different story.
I'm not google or a cooling system scientist. This is just how I figure it
If the vehicle has swapped radiators for one with much more cooling capacity, it IS possible for the fully warmed engine to run at T-stat rated temps. But, that is certainly NOT the normal for a stock configuration cooling system.
And, I stand by my statement that if a cooling system with a 180*F T-stat installed has a stable running temp of 190*F or higher, it will STILL run at that temperature with a 160*F T-stat installed. The T-stat sets the LOWEST running temp possible in any cooling system. But, it does NOT limit the actual running temperature of the engine. That is established by the actual capability of the cooling system's capacity to remove heat.
If the T-stat is 160
and the engine is sitting at 161*F+ on the inlet
it means the radiator/fans/airflow is insufficient to carry enough heat away to close the T-stat (bring temp down)
It means the entire cooling system needs to be 'fixed'.
Not because you want the water 160, but because it clearly has a problem rejecting heat...
And, I stand by my statement that if a cooling system with a 180*F T-stat installed has a stable running temp of 190*F or higher, it will STILL run at that temperature with a 160*F T-stat installed. Yep! But if it's running higher than 190* with a 180* ts, then there is a cooling problem e.g. rad is too small or scaled up. If the rad has a high capacity, then a 160* ts will keep the engine at 160*-ish. The OP just posted his results and I don't doubt his results whatsoever.
The T-stat sets the LOWEST running temp possible in any cooling system. That's one function of a ts but there's more to it than that. "Lowest" running temp is the "normal" engine operating temp. Also decreases warm up time, prevents engine from overheating. And, it sets the engine's operating temp vice the temp in the cooling system. Not all heat generated by an engine is removed by the coolant.
But, it does NOT limit the actual running temperature of the engine. Yes, it does.
That is established by the actual capability of the cooling system's capacity to remove heat. The majority of heat removed from the engine is done by the (properly sized/capacity) radiator i.e. heat exchanger, by cooling the coolant heated by the engine and lowering the temperature of the coolant for re-entry into the engine to displace the heated coolant. This process is controlled by the ts by varying the opening the ts's valve to maintain a near constant engine temperature dictated by the ts's rating.
Pretty simple for most folks to understand but for some reason some folks don't get it. In a nutshell, to remove more heat from an engine, put in a bigger rad. To run an engine at 160* will require more heat removal but easy to accomplish by putting in a bigger rad. If I want my engine to run at 500*, for arguments sake, I would use a ts rated at 500* and use a much, much smaller rad. Maybe the size of my heating core, lol!
That being said, a stock cooling system is design with a maximum capacity, plus a certain percetage. I know for a fact that when a thermostat sticks open, the egine will run cool., providing the cooling system was in good condition. I haven't studied this for a while but i know the thermostat will regulate itself to maintain the temperature it is designed for. A 160 will maintain 160 degrees, a 185 will maintain 185 and so on. Engines run hot due to other conditions. Modified engines will run hotter, i think most readers here understand that. I think th OP actually answered the question, he installed a 195 stat and the engine ran at....... 195.
Now lets discuss thermal dynamics and motor oil viscosity....... 😀
