1980 Driver side mirror
Old Jun 24, 2019 | 04:34 PM
bcandreesen's Avatar
bcandreesen
Navigator
Default 1980 Driver side mirror
Driver side mirror, top part wobbles on the pedestal. Can that be tightened or time for a new one?
Old Jun 24, 2019 | 05:12 PM
Thehanseh's Avatar
Thehanseh
6th Gear
No need for a new mirror it’s bolted from underneath. But it’s quite tricky to fix. Usually you have to dissemble the door panel and take out the window. But I fixed it even without loosening the window.
1) remove door panel (should be clear)
2) lower window
3) take out the two top window stops
4) find a way to reach the stupid second screw behind the window
But you really need patience and flexible fingers. But I’d definitely do it again without removing the windows. Saves a lot of adjustment time.
Good luck
Kevin
Old Jun 24, 2019 | 06:23 PM
bcandreesen
Navigator
Thanks Kevin
To 1980 Driver side mirror
