Spark plug question
Old Jun 28, 2019 | 11:18 PM
interpon's Avatar
interpon
Default Spark plug question
Hi
79 l82, trying to change plugs and wires....holy cow what a job..
anyway rock auto ac delco r45ts and the body is significantly longer amd concerned with all the toght fitting ot may be anissie anyone run into?
im also big oem especially plugs, bit these longer china plugs concern me..was thinking ngk
https://www.autozone.com/miscellaneous-non-automotive/non-automotive-spark-plug/ngk-standard-spark-plug/518892_0_0?CAWELAID=120054150000924282&c mpid=PLAS:EN:AD:NL:1000000:SPP:1700000 871&gclid=EAIaIQobChMInbTpi9yN4wIVRT0MCh 1ARgyfEAkYASABEgLOYPD_BwE&gclsrc=aw.ds
thank you for advice
Old Jun 29, 2019 | 07:19 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
The longer plug above the threads means its a colder plug I believe. the part to worry about is the theaded part that projects iinto the cylinders. IF that part is the same then you dont have a clearance issue to worry about internally. Now a colder plug versus a hotter plug is another can of worms that will get really confusing fast with a lot of engineer types throwing all sorts of info at you here. If you have stock iron heads look at the original plug heat range index. If you have aluminum heads, find out what the manufaturer designed them to use with what compression. My aluminum heads manufacturer wanted a specific NGK plug.
Now externally for the length, are you running any of the external shielding or headers? Usually with headers there can be a clearance issue
Old Jun 29, 2019 | 08:13 AM
interpon's Avatar
interpon
Thanks..the part that is weird is it is identical numbers r45ts..no headers bone stock L82..manual and reproduction owners manual says thats the plug..heat shield yes, the factory nightmare..i will get a coil and maps and see if same there too.
after seeing thos mess and China plug..i was cnsidering ngk equivalence
Old Jun 29, 2019 | 10:22 AM
interpon's Avatar
interpon
Forced my hand ...NGK length will work (slightly longer than originals) as at least one heat shield no way getting plug wrench on it..
made in japan..even closer to original size..i noted the ac chine one had slightly shorter threads..
insulator is only difference i see and all other sizing identical to original
fyi i had napa pull their ac delco and was the same as other. Compared on counter
Old Jun 29, 2019 | 10:26 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I don't think that NGK is the correct replacement for the R45TS. This cross reference chart indicates otherwise:
https://www.sparkplug-crossreference...AC_DELCO/R45TS
I use the NGK v-groove in my AFR aluminium heads btw.
Old Jun 29, 2019 | 08:13 PM
interpon's Avatar
interpon
Says ngk ur4 compatible..look better match than ac delco
what a pos the cap was too..and echlin coil..had to remove some plastic to fit center pin and then it broke installing..
omg what a chore on the wires someone slap who came up with that heat shield..
very happy with old plug colors!
Old Jun 30, 2019 | 12:26 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
A set of NGK's is only ~$20. Why not give 'em a try?
Old Jun 30, 2019 | 12:27 PM
interpon's Avatar
interpon
Yup
i did runs perfect iforgot what a tuneups does on older cars..man that wiring plug wores and heat shield was a chore,,..
To Spark plug question
