Air Compressor Gets HOT
Old Jul 3, 2019 | 03:49 AM
BF240's Avatar
BF240
8th Gear
Default Air Compressor Gets HOT
The factory original air compressor on my C3 '72, Stingray got very hot even though the air conditioning was working normal. No noise from the clutch, and it would click on and off properly when turned off. The clutch was hot to the touch and the middle of the compressor very warm. It became hot enough to bubble the paint on the outside of the hood.
The air compressor has been converted to 34.
What tests should I make on the compressor?
Old Jul 3, 2019 | 09:28 AM
interpon's Avatar
interpon
Not sure of details of the 135a conversion...but maybe?
- never added correct oil for 134a? Pretty sure 134a will not suspend mineral oil to lubricate compressor , do you know details of course conversion?
- check pressures with gauges...maybe over filled? 134a i think requires less material than r12..
got an ir gun? They are cheap..see what it says..
Old Jul 3, 2019 | 11:24 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
This obviously is much too hot. I think lubrication is one important possibility as described above, but I find it hard to believe that it was cooling the car if it was the wrong lubricant. Certainly possible that there is no lubricant. Rather than guessing, here’s a pretty good link for diagnosing A/C issues, albeit for imports. Won’t cover the conversion issues though.
https://mdhmotors.com/ac-compressor-...gnosis-repair/
Old Jul 3, 2019 | 09:46 PM
7T1vette's Avatar
7T1vette
134a requires PAG oil, instead of mineral oil. The two oil types WILL NOT MIX...or, specifically, should not be mixed. Some folks drain the mineral oil, but don't clean/purge the system. They'll put some ester oil in with the new PAG oil, hoping that the residual mineral oil will not cause any problems. If you still have mineral oil in to lube your compressor, you have a problem.
To Air Compressor Gets HOT
