Neutral safety reverse switch
Old Jul 6, 2019 | 08:17 PM
titanle's Avatar
titanle
Default Neutral safety reverse switch
Hey guys I had another question. I opened up the centre console and I can’t tell whether I am missing the neutral switch that controls the backup lights. My reverse lights don’t work at the moment.
I also saw that there is a 68 and 69 style of switch and again since my car is all sorts of different year parts I can’t tell if I would need a 68 or 69 switch
Old Jul 6, 2019 | 08:32 PM
TimAT's Avatar
TimAT
I don't see the neutral switch in your pictures either. Are there 2 multiple connector plugs laying in there somewhere?
Old Jul 6, 2019 | 08:33 PM
titanle's Avatar
titanle
I’ll take a picture from the driver side. I couldn’t see a plug from the passenger side
Old Jul 6, 2019 | 08:57 PM
71 Vert LS1's Avatar
71 Vert LS1
It's easy to tell if the switch is working. Does the car start in drive and reverse? It shouldn't. Should have at least a purple wire that goes to the start circuit.
Old Jul 7, 2019 | 07:50 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
this is what it looks like and where it goes, the wiring should be right there, the tails are really short
https://www.ecklerscorvette.com/diag.../index/id/143/
https://www.ecklerscorvette.com/corv...sion-1968.html
Old Jul 7, 2019 | 08:10 AM
derekderek's Avatar
derekderek
links just go to eckler's main page, Roger.
Old Jul 7, 2019 | 08:19 AM
Rescue Rogers
I'll try a finding another link then. But the diagram showed it mounted to the passsenger side and the wiring pigtails wherejust a few inches long.
Should have thought to check Ernies site first......
heres WILLCOX site
http://repairs.willcoxcorvette.com/w...stment-wat.jpg
https://willcoxcorvette.com/corvette...utomatic-68-68
Old Jul 7, 2019 | 03:25 PM
titanle's Avatar
titanle
seems like mine is absent, nothing on the passenger side. I have a feeling its missing because the car was changed from a 4spd to auto somewhere along the line.
Old Jul 7, 2019 | 03:56 PM
Rescue Rogers
that could be it, I wonder of you could find a wiring diagram and add it in. If the backup light harness is there for the manual tranny you could just wire in a toggle switch for the backup lamps
Old Jul 7, 2019 | 04:32 PM
ntfday's Avatar
ntfday
Veteran: Marine Corps
If I was you I'd jump on this https://www.ebay.com/itm/1968-76-CHE...QAAOSw-IFcyw2W
Old Jul 7, 2019 | 07:50 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
Originally Posted by ntfday
Yes, that is the whole thing, pretty good deal i think.
Old Jul 8, 2019 | 10:12 AM
titanle's Avatar
titanle
That is a good deal. The switch alone is around that much, i think id rather just buy the switch since its brand new, who knows how old the switch on that listing is.
Old Jul 8, 2019 | 10:19 AM
Kacyc3's Avatar
Kacyc3
Was your car a factory auto car?
Old Jul 8, 2019 | 10:26 AM
titanle's Avatar
titanle
no it was a 4speed originally
Old Jul 8, 2019 | 10:52 AM
TimAT's Avatar
TimAT
I just replaced the harness in my 69. All the connectors/wires are there for either a manual or an auto trans. Just plug in the ones you need or not. I ran a wire from the console neutral start switch out thru the firewall to a terminal for a remote start button. Handy for adjusting valves as a one man show. Just make sure the 4 speed is in neutral before you hit the button.
Old Jul 8, 2019 | 02:20 PM
titanle's Avatar
titanle
I was looking at the 69/69 switches and it appears the only difference is what the plug connectors look like. The mounting point to the gear shift both look the same. Is this the only difference? Theoretically I would be able to determine which switch i need by looking at the connectors that are coming out of my harness?
To Neutral safety reverse switch
