Test pipe vs gutted cat
Old Jul 9, 2019 | 09:15 PM
Wrecked82's Avatar
Wrecked82
Default Test pipe vs gutted cat
Removed smog equipment months ago with no negative effects,
Would any benefit come from a test pipe or a gutted cat? Sound mostly is wanted. There is only so much performance available from a mostly stock 82. Gutted cat would look closest to a stock setup if the ****'s come after me. But smog stuff already long gone.
Will be cutting off remaining piping on existing cat.
If going to remove stock might as well as just gut it?
Old Jul 10, 2019 | 06:59 AM
KenSny's Avatar
KenSny
If the smog stuff is already gone, then a piece of pipe is the least of your worries if they come looking.
Go true 2-1/2" duals.
Old Jul 10, 2019 | 10:01 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
What Ken said.....unless money is an issue. You will notice an improvement in performance cat-less...dual exhaust will give better performance and sound BETTER.
Old Jul 10, 2019 | 10:20 AM
Kacyc3's Avatar
Kacyc3
in this order
stock
removed smog
gutted cat with cat back duals
test pipe with cat back duals if your that worried about the cat being removed gut it then run a pipe through it . (gutted cats supposedly cause turbulence, this would solve the issue)
true duals
after that you have to get into the engine and or ECM.
Old Jul 10, 2019 | 10:26 AM
Roy W.'s Avatar
Roy W.
Disabled by request 8 JUN 2025
I went with true 2 1/2 inch duals on my smog-less 82. The sound is beautiful (may need an H-pipe) to tone it down a bit at WOT. Rams horn exhaust manifolds with a 2 1/2 inch exit is my next mod. The OEM stainless manifolds have a leak where the 4 runners converge.
Old Jul 12, 2019 | 09:30 PM
Wrecked82's Avatar
Wrecked82
Problem is finding a test pipe.
Old Jul 12, 2019 | 10:01 PM
bmonteer's Avatar
bmonteer
There was one on eBay I bought one and ther was another one..it bolted right on and yes there is more sound that comes with the test pipe a much more throaty sound..a little more volume I have the stock mufflers in place as well..
Old Jul 12, 2019 | 10:02 PM
bmonteer's Avatar
bmonteer
this is what your looking for
Old Jul 12, 2019 | 10:03 PM
Richard454's Avatar
Richard454
This "looks" like a win-win!!!
Amazon-
Amazon Amazon
Old Jul 12, 2019 | 10:04 PM
bmonteer's Avatar
bmonteer
I just checked eBay and there is one available if your looking for one
Old Jul 12, 2019 | 10:09 PM
bmonteer's Avatar
bmonteer
I don’t think you would have any issues with emissions because of the cars age I know here in Kansas it is exempt ..yes I think it runs a whole lot better without the cat on I don’t have any emissions controls on my 82 ..
Old Jul 14, 2019 | 09:30 AM
stingr69's Avatar
stingr69
Original smog era mufflers are designed to work after a cat so the car will be louder than a stock system if you disable the cat.
I have the true duals setup now but am considering putting the original pipes back on with the test pipe I acquired. I know that seems crazy but I do have a reason.
Old Jul 14, 2019 | 11:00 AM
KenSny's Avatar
KenSny
I will agree with you on the "seems crazy" part.....
So instead of changing mufflers you are going to go change out the true duals and go back to the restrictive Y-pipes?
Old Jul 14, 2019 | 08:55 PM
terry82's Avatar
terry82
opening up the factory cat cost nothing.put it back on and see if you can tell a difference .tru duals can help .best change would be the intake.heads and cam.
Old Jul 14, 2019 | 09:19 PM
interpon's Avatar
interpon
Link for the ebay pipe? I want to get rid of the cat for now as it got so hot before i see a brown burn spot ubder passenger seat on oyster carpet..it gets about 500f and heat shield rattlng..assume no heat shield needed with pipe?
Old Jul 14, 2019 | 10:18 PM
Bikespace's Avatar
Bikespace
Sidepipes? Asking for a friend.
Make sure you add shields, too.
Old Jul 14, 2019 | 10:25 PM
Wrecked82's Avatar
Wrecked82
I have seen the post. Try a simple google search on ebay motors for test pipe.
Old Jul 14, 2019 | 10:26 PM
interpon's Avatar
interpon
Yup i did that..was wondering which one stated bolted right in..from experience
To Test pipe vs gutted cat
