Old Jul 25, 2019 | 08:19 PM
ls5bigblock's Avatar
ls5bigblock
Default 1969 427
I have a 69 427 390hp The vacumn fitting on intake manifold has 3 ports one for pb the other is for headlights and wiper door I don’t know what the other port is for. Thank you for any info Tony.
Old Jul 26, 2019 | 06:45 AM
3X2's Avatar
3X2
Auto trans vacuum modulator pipe???
Old Jul 26, 2019 | 07:32 AM
derekderek's Avatar
derekderek
i think there are 2 vacs for headlights and wipers. small one goes thru dash to go to switches-relays. big one goes to vac tank for the higher flow needed for opening-closing actuators. kind of like a low amp wire activating the relay and a high amp wire powering the fans, lights,etc.
Old Jul 26, 2019 | 08:04 AM
Gordonm's Avatar
Gordonm
That is not a factory fitting either. Probably had one in the tool box and put it in and capped the unused one off.
To 1969 427
