Transmission cooler lines
Old Jul 26, 2019 | 12:12 PM
fake's Avatar
fake
Default Transmission cooler lines
Need to make some hard lnes ! What tools do i need? Is a flair needed on both ends for attachment to rubber lines?
Old Jul 26, 2019 | 12:16 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You can buy the lines through the Corvette aftermarket providers. No need to make your own.
Old Jul 26, 2019 | 03:13 PM
7T1vette's Avatar
7T1vette
You can easily make your own. But, you must remember to put a "bulge" on the end of the hard line that connects to the rubber hose (so it can't slip off when clamped).
Also, you MUST use high pressure hydraulic hose; oil from the 'cooler out' line exits at around 100 psi. When oil is cold, those hose pieces might se 40-50 psi at times.
Old Jul 26, 2019 | 03:36 PM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
Agreed and also less chance of problems when you go through the Corvette aftermarket providers.
Old Jul 27, 2019 | 09:58 PM
7T1vette's Avatar
7T1vette
Most aftermarket vendors just sell the stuff supplied to them. Much of it is foreign-made. Rubber products are not something that they do well. All you need is a couple of short pieces of good hydraulic hose. Most 'good' auto parts stores can cut what you need off batch reels of hose.
Old Jul 28, 2019 | 09:56 AM
TimAT's Avatar
TimAT
Transmission Cooler hose is marked clearly "Trans Cooler". Don't let some parts store guy cut you a piece of hose and tell you it's ok for trans cooler. It's not. Vacuum/Fuel line won't stand the heat, oil, and pressure.
Old Jul 29, 2019 | 12:40 PM
fake's Avatar
fake
They tell me brake lines will do for oil cooler lines (Transmission)What psi we looking at any rubber lines are okay?
Old Jul 29, 2019 | 04:49 PM
HeadsU.P.'s Avatar
HeadsU.P.
Different diameter ! ?
Old Jul 29, 2019 | 05:12 PM
dmaxx3500's Avatar
dmaxx3500
a company in ohio sells pre-bent fuel-brake-trans lines
''THE RIGHT STUFF'',,THEY MAKE MOST OF THE LINES YOU FIND AFTERMARKET,and on new oem cars too
in regular and doubled annealed stainless
Old Jul 29, 2019 | 08:15 PM
derekderek's Avatar
derekderek
i would think fuel injection hose would work.
To Transmission cooler lines
