A/C system...
Old Jul 28, 2019 | 08:17 PM
clajac's Avatar
clajac
Default A/C system...
Anyone know the correct amount of Freon to put in a c3 system...…...Thks
Old Jul 28, 2019 | 08:49 PM
interpon's Avatar
interpon
My 79 l82 takes 3 pounds r12, iit actually took less than that to get correct readings.
oil capacity on mine total is 6 ounces mineral oil..again using r12
Old Jul 29, 2019 | 08:14 AM
clajac's Avatar
clajac
Thks. I going to use r134a for my system...……….
Old Jul 29, 2019 | 08:26 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Buy a spare can of refrigerant.....If you do, you'll never need it! Also, you probably know to use a vacuum pump to remove air/moisture from the A/C plumbing.
Old Jul 29, 2019 | 09:06 AM
interpon's Avatar
interpon
Then folks say use about 85% of R12 for 134a.
use gauges.
here is a chart shared with me.
Old Jul 29, 2019 | 10:13 AM
69_Shark's Avatar
69_Shark
Also, if you have had the system open to the world for any length of time, you might want to replace the dryer.
35-40 bucks, easier and cheaper to do it now!
Scott
Old Jul 29, 2019 | 10:17 AM
interpon's Avatar
interpon
Scott
Yup and if you are switching to 134a you MUST replace dryer and orifice and flush old oil out, i would remove compressor and drain..then when confident 90 percent or more old oil out, and system does not leak.( check prior to disassembly) add correct oil and vacuum heavy..load go..
i would also pressure check to at least 100 psi and see if it hold first..for about 20 minutes
Old Jul 29, 2019 | 09:20 PM
clajac's Avatar
clajac
Default A/C System
Thks for the info and chart, should be very helpful...……..System was open when I obtained the car, I've replaced dryer, hoses, orfice tube and compressor, My first compressor locked up for some reason, anyway giving it another try....
To A/C system...
