Short differential question
Old Jul 31, 2019 | 08:38 AM
Lionom's Avatar
Lionom
Default Short differential question
Hello guys,
I want to change the differential oil on my c3 L-48 from 1979. I need to know which size of the differential cover gasket i must use. thanks for any help.
Old Jul 31, 2019 | 08:51 AM
joewill's Avatar
joewill
https://www.zip-corvette.com/63-79-d...er-gasket.html
Old Jul 31, 2019 | 10:35 AM
bradleyb66's Avatar
bradleyb66
Is the diff already removed from the car? If not, note that the cover does not come off like other straight axle diffs. You're probably better off suctioning or siphoning the old gear oil out thru the fill hole. If I remember correctly, I used a turkey baster and a couple feet of clear tubing. (and don't forget to add the GM posi additive).
Old Jul 31, 2019 | 11:14 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Buy an oil suction gun from HF for a few bucks to remove/replace the gear oil if that's all you want to do.
Old Aug 2, 2019 | 09:16 AM
Lionom's Avatar
Lionom
thanks for the replys, i will take a suction gun
Old Aug 3, 2019 | 10:05 AM
davidchristopher's Avatar
davidchristopher
When you climb under to do it, you'll see why. The diff housing is structural.
To Short differential question
