72 BB hood clearance L88 drop base?
Old Aug 3, 2019 | 09:54 PM
70rs/ss396's Avatar
70rs/ss396
Default 72 BB hood clearance L88 drop base?
Hello
I know that the only intakes that fit under original BB hood is the torker 2 and the original ones.
But when you look at the height at the six barrel intake, it seems to be pretty high?
So a performer or performer rpm with a L88 drop base and 14" filter shouldnt it fit?
The torker 2 and other original intakes, is it only when you use original air cleaner other intakes wont fit?
Thank you
Old Aug 4, 2019 | 01:11 AM
ddawson's Avatar
ddawson
3.570, L36 intake
3.820, Torker II
4.850, Performer
5.000 WEIAND STEALTH INTAKE
5.220, Performer RPM
You could try using a 2" filter but they may cause airflow issues.
Old Aug 4, 2019 | 06:49 AM
70rs/ss396's Avatar
70rs/ss396
How much does the stock 454 base drop vs the L88?
Old Aug 4, 2019 | 07:08 AM
derekderek's Avatar
derekderek
It is mainly the flat top as opposed to angled top on OEM intakes. I did some comparisons with my intakes and the back of a Vic Jr is same height as the back of a stock high rise GM.
To 72 BB hood clearance L88 drop base?
