Steering problem.
Old Aug 4, 2019 | 02:43 PM
curtis200's Avatar
curtis200
5th Gear
Default Steering problem.
My 78 was driving as normal down the road, not too fast about 25-30 mph. I hit a small bump and the front wheels started bounding/wobbling back n forth, left n right. I thought i was going to wreck, the steering wheel was shaking.
I stopped the car and checked the wheels. I looked under the car too. Nothing seems wrong. I started to drive again and it seemed to steer just fine. I hit another small bump and the same thing happened.
Curt
Old Aug 4, 2019 | 03:02 PM
l82vett's Avatar
l82vett
I wouldn't be driving it until you find out what is causing that. You have something real loose. Jack up the front , put a jack stand under the frame, you can do 1 side at a time, grab the tire and try to move it back and forth. Could be a wheel bearing, tie rod end or steering.
Old Aug 4, 2019 | 03:34 PM
curtis200's Avatar
curtis200
5th Gear
Yes, i'll look real soon.
Old Aug 4, 2019 | 04:54 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
I would check your idler arms and tie rods. lower ball joints are common too. uppers hardly go bad
Old Aug 4, 2019 | 07:21 PM
HeadsU.P.'s Avatar
HeadsU.P.
Did you just finish work anywhere on the P.S. system? Sounds like a air pocket still in the system. (control valve)
Old Aug 4, 2019 | 07:42 PM
curtis200's Avatar
curtis200
5th Gear
Heads UP, I did last year. I replaced the PS pump and the Control valve. If that's the case, whats the fix?
Should I turn the wheel all the way left and right?
Old Aug 5, 2019 | 05:31 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Wow, that sounds like the 89-91ish Jeep cherokee death wobble. Those jeeps are known for that scary crap. They have allignment issues with caster or some such thing.
For the power steering, you cycle the wheel stop to stop like 20 or 40 times to get the air out. then make sure the valve balance is centered. You can find the procedure in the AIM i think, or on Willcox's site.
Old Aug 5, 2019 | 07:16 AM
HeadsU.P.'s Avatar
HeadsU.P.
That death ride happened to me hours after one P.S. line was replaced. Never happened again after I did a "better" job of bleeding the air out.
With vehicles front on jackstands.
Start engine.
Turn steering wheel "Lock To Lock" 6-8 cycles.
Check fluid level again once the vehicle is on the ground.
Old Aug 5, 2019 | 09:37 AM
Bikespace's Avatar
Bikespace
In addition to the easy suggestions above, I'd check your lower ball joints, and front wheel bearings. You may be able to tell by jacking the car off the ground, and yanking on the wheels (safely). Your best bet might be to take it to a Corvette or classic car mechanic, get the car on the lift, and get a second opinion. If you need all of your bushings replaced, it may not be one thing that fixes it.
Old Aug 5, 2019 | 07:58 PM
HeadsU.P.'s Avatar
HeadsU.P.
When the control valve and slave cylinder have equal line pressures, the wheels will stay straight. Equal pressure left, equal pressure right.
When an air pocket is introduced the bubble has to travel through the control valve, the lines, then on to the cylinder. If the bubble enters the "steer left assist" line, the "steer right assist" over compensates. Then the reverse happens. You will get the steering wheel shimmy effect until the air purges itself.
For some reason your control valve got confused as to where to send the fluid pressure. That's why I asked about recent PS repairs. Introducing air into the system.
To Steering problem.
