brake vacuum low
Old Aug 15, 2019 | 06:50 PM
pav's Avatar
pav
3rd Gear
Default brake vacuum low
hi, an oversized cam has made my brake vacuum low so the car does not stop quickly. dangerous. the power brake booster is new. anything else that I can do? a hydro booster? not sure I want to do that. A larger booster? there's no room in that area of the engine. its a 1975 stingray.
Old Aug 15, 2019 | 06:59 PM
scottjamison's Avatar
scottjamison
Ah yes, the struggle of the high overlap cam. Many have gone through that here.
I went through a LOT of headache with mine. I had all Wilwood components and still felt like ****.
The way I see it there are 3 options, 2 of which I tried:
1. Add a vacuum pump. Pros - You still get power brakes. Con - Big, heavy, and loud as hell and still not consistent. Pump ~$200
2. Switch to manual brakes. I chose that route. I am fairly happy with them. Pros - Consistent and more room in engine bay. Cons - a bit more pressure required from your foot. Will require a probable change in master cyl and new brake lines going into the MC.
3. Hydroboost. Pros (that I know of) works really well from the reviews and still power assisted brakes. Cons - cost and complexity. Not sure about the cost.
There is a lot of info on here about the brakes and dealing with low vacuum but those are the 3 choices I have seen.
Your choice.
Old Aug 15, 2019 | 07:12 PM
pav's Avatar
pav
3rd Gear
Default thanks very much
thanks very much. very helpful !
Old Aug 16, 2019 | 07:13 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
They make quiet pumps but they may be a bit more expensive but they are smaller too.
Heres one with good reviews
https://www.summitracing.com/parts/leb-vp001c/overview/
Theres a few in the car magazines like hotrod, etc,....
Old Aug 16, 2019 | 11:55 AM
scottjamison
Still a good size, but if it is quieter than the one I had, that would be a huge plus. Mine sounded like a 600cc thumper motorcycle.
Old Aug 16, 2019 | 12:36 PM
Rescue Rogers
They sell it without the chrome cover to make it smaller as well, or you can just remove the cover
Old Aug 16, 2019 | 02:00 PM
7T1vette's Avatar
7T1vette
You can now buy ELECTRIC power brake kit...it requires NO VACUUM!! I don't know the cost, but this may be a more viable option.
http://www.abspowerbrake.com/ehpm.html
To brake vacuum low
