Sunken Float
Old Aug 27, 2019 | 05:35 PM
intihar3's Avatar
intihar3
1st Gear
Default Sunken Float
have a 72 coupe and after 5 long years I have put it on the road. I
replaced the gas tank and sending unit about a year ago. My problem is
the float on the sending unit does not float. If I manually move it up
using a wire the gas gauge works then when I let it go it float backs
down to the bottom. Any idea why the float is not floating? Any fixes
beside a new sending unit?
Old Aug 27, 2019 | 06:42 PM
loup68's Avatar
loup68
Army
Someone on here may have a good float to sell you and all that you need to do is change just the float. Lou.
Old Aug 27, 2019 | 06:49 PM
derekderek's Avatar
derekderek
float failed the float test...
Old Aug 27, 2019 | 07:09 PM
Zealot's Avatar
Zealot
Veteran: Marine Corps
Wouldn't that make it a sink? Maybe its on upside-down?
To Sunken Float
