Classic Auto Air Custom Controller Question
Wondering if anyone has done a custom control using the Classic Auto Air D.E.R. control ported into the OEM AC control on the shifter bezel. The Corvette’s OEM AC controller with the wheel control has a cool factor to it and the Classic Auto Air plastic controller kinda looks like plastic crap.
Thinking of pulling the fan switch and heat/vent slide controls out of the Classic Auto Air plastic box and jerry-rigging them to the underside of the OEM AC controller. Or using the stock fan switch and rig a couple of potentiometers connected to the OEM AC controller wheels….
Has anyone done anything like this?
Richard
Good luck, let us know what you end up doing.
I did read a forum post somewhere that talked about CAA being spun off from an ex-employee of VA and that the systems have some similarities. I am wondering if the VA Controller kit would work with the CAA systems with some minor alterations and calibration... Challenge accepted!
**UPDATE**
The CAA "D.E.R." controller comes with 10K Ohm slide pots (Confirmed with a meter as well as CAA tech resource)
The VA controller kit comes with 12K Ohm slide pots. Confirmed by VA tech resource.
The VA pots should work with my CAA system so I ordered a VA controller kit and will update this post with the results when testing is completed
Richard
Now with others having interest and for the cause, I will bump it up the priority list and try to finish it up this weekend. I'll take some pics, do up a quick wiring drawing and share it out
Cheers,
Richard
Note: The VA resisters are actually 10K Ohm contradicting the VA tech that I spoke with over the phone stating that they were 12K Ohm. This is a good thing in that both VA and CAA systems use 10K Ohm system mode control resisters
The first Picture is the VA harness from the VA manual.
The second picture is the out of box CAA DER and wire harness mapped out. The resistance per mode is also documented in this picture.
The third picture is the stock C3 Corvette controls modified with the VA kit (resisters and harness). The VA three pin plugs connected to the VA resisters with their wires cut, soldered and heatshrink tubed to the corresponding mapped out CAA DER harness plug that connects the assembly to the CAA system. The resistance per mode is also documented in this picture.
Picture One
Picture Two
Picture Three
Cheers,
Richard
As you can see in the “VA wire harness As-Is”, the Red wires are all tied together and the White wires are all tied together. So, it looks as simple as soldering the CAA White and Green wires to the VA White wire and soldering the CAA Violet and Blue wires to the VA Red wire.
As per my write-up, I have not tested this but from a conceptual perspective, it all should work.
Please make sure that you are competent with wiring and soldering and make sure that you ohm it all out with a meter for yourself before connecting it to your CAA or VA core system.
I should have this all working in a couple of weeks and I will update my results in this thread.
Cheers,
Richard
