Engine casting numbers 1969
Old Sep 12, 2019 | 05:47 AM
Jerad Brannen's Avatar
Jerad Brannen
5th Gear
Default Engine casting numbers 1969
Anybody know what T 03 25 H stands for? Cant find the H anywhere online anywhere
Old Sep 12, 2019 | 05:49 AM
Jerad Brannen
5th Gear
Or if they are even original numbers
Old Sep 12, 2019 | 06:04 AM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
What motor is it ,The T stands for Tonawanda H at end Maybe 427 390 HP transistor ignition ?
Old Sep 12, 2019 | 06:13 AM
sug's Avatar
sug
Does it read T0325MH
Old Sep 12, 2019 | 06:15 AM
Jerad Brannen
5th Gear
Supposedly it's a 427 400. There is definitely nothing between the 25 and the H except for a space.
Old Sep 12, 2019 | 06:50 AM
sug's Avatar
sug
I would clean the pad with acetone or paint thinners to be sure
Old Sep 12, 2019 | 07:31 AM
3X2's Avatar
3X2
If it is a 69 big block, MH is the only code I have found. 427/390, manual trans, transistor ignition.427/400 would be either a MJ or MK.
Old Sep 12, 2019 | 08:22 AM
bbvette427's Avatar
bbvette427
Here is a picture of my engine stamp.
Old Sep 12, 2019 | 11:56 AM
joewill's Avatar
joewill
the only engine code on a 69 corvette big block with a H is MH - a 427-390, (not a 400).
that seems to be missing a M.. might have been a bad stamp strike.. remove the paint and look for a faint M.
that stamp looks to have good broach marks so a good chance of being legit. but the old paint negates the possibility somewhat.
check the casting date of the block...
Old Sep 12, 2019 | 01:34 PM
cv67's Avatar
cv67
St. Jude Donor '05
Why the magic marker?
Old Sep 12, 2019 | 03:17 PM
ed427vette's Avatar
ed427vette
I agree with Joewill. The vin stamp looks factory but the date portion is not typical. The broach marks look good where they can be seen. Remove the paint on the rest of the pad very carefully with some lacquer thinner without scratching the stamp pad. Just gently rub the paint thinner along it.
Old Sep 12, 2019 | 04:56 PM
Jerad Brannen
5th Gear
Thank you. That's kind of what I was assuming. Gonna do that this weekend. Googling to how check the casting date now. Should it be the same as that stamp?
Old Sep 12, 2019 | 06:56 PM
joewill's Avatar
joewill
engine date casting code is back behind the distributor on the flange where the bellhousing bolts on. there will be a casting number on one side and a casting date on the other side.
and no, it will not be the same as the assembly date stamping. it is usually a few days to a few months before.
Old Sep 12, 2019 | 07:07 PM
derekderek's Avatar
derekderek
Magic markers because he did not want to give away his Vin number.
Old Sep 12, 2019 | 08:01 PM
Jerad Brannen
5th Gear
Yeah it say C 11 9. So I guess March 11 69. So 2 weeks before stamp.
To Engine casting numbers 1969
