Steering wheel replacement question
Old Sep 19, 2019 | 08:52 AM
RLJ 1976's Avatar
RLJ 1976
2nd Gear
Default Steering wheel replacement question
THE VEGA .............. How easy is it to add the kit to accept a tri spoke wheel to the telescoping column thats on a 1976 C3? Should i replace the entire column or just add the kit to the existing one? Thanks !
Old Sep 19, 2019 | 09:54 AM
ntfday's Avatar
ntfday
Veteran: Marine Corps
I changed the wheel in my 76 a couple of years ago with a kit from Willcox,I believe,, and it's not difficult at all. The only trouble I've had is with the horn and that's an alignment problem. Good luck
