Distributor shield cover
Old Sep 24, 2019 | 10:51 PM
l82vett's Avatar
l82vett
Default Distributor shield cover
I have over the last 55+ years have owned many cars from Vw's , Honda, Ford , Dodge, Plymouth,Mercury, Pontiac's and even other Chevrolets + some more. None had the distributor cover shield. What was / is the reason for it on a Corvette and not on any other car?
Old Sep 24, 2019 | 11:05 PM
radiotexas's Avatar
radiotexas
I was always told it was to reduce "noise" to the radio. I have a 1970 big block with the shielding and grounded woven "metal" jackets on the plug wires from ignition box to the plugs. I don't know if the effort works as you can't hear the radio when the engine is running. Radio is easily heard when the engine is not running.
Okay, a little pulling of your leg, but seriously, many consider the sound level obnoxious, but it sounds like music to me.
Old Sep 24, 2019 | 11:08 PM
general ike's Avatar
general ike
2017 C3 of the Year Finalist
St. Jude Donor '20- '21
It was designed to block the "noise", static that the electrical system would cause on the radio. I guess, I don't really have a clue, that a metal body car would shield the radio and thus not necessary. In fact if you ordered a car without a radio the shielding was left off. Please be careful some of the shielding you see on the engine is for heat and is heat shielding. I hope I got this correct. Someone will come along and verify all this!! Ike
Old Sep 24, 2019 | 11:15 PM
thatcorvetteguy's Avatar
thatcorvetteguy
I like it or anything that could reduce the possibility of a spark meeting fuel on a plastic car.
Old Sep 25, 2019 | 12:03 AM
CanadaGrant's Avatar
CanadaGrant
It was because of the fiberglass cowl between the engine compartment and interior instead of metal but it was mostly just for AM radio. Never mattered much for FM and when was the last time you found an AM station? My first Corvette was a 69 427 that I bought in 1970. I removed all that ignition shielding, smog equipment and other "worthless" stuff and tossed it in the garbage. I think that was just before I took the same original black on black 1969 427 coupe with about 2000 miles on it and painted it green.
Crazy and then some...
Back to reality, you won't notice it missing but it looks cool and, um, what was the question again?
Old Sep 25, 2019 | 12:19 AM
revitup's Avatar
revitup
Guess I can buy the radio noise reason regarding the chrome distributor shields but aren't there some with black plastic shields? How's that do anything to reduce radio interference?
Old Sep 25, 2019 | 08:59 AM
stingr69's Avatar
stingr69
Black plastic....lined with metal foil on the inside. Kind of a tin foil hat.
Old Sep 25, 2019 | 10:51 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Corvettes gotta look cool and unique. T
Old Sep 25, 2019 | 02:30 PM
L-46man's Avatar
L-46man
Radio noise suppression ONLY.
Following on...Notice that the spark plug wires are the 'suppressor type'...same reason.
Induced 'popping' on AM due to lack of Faraday cage like metal structure.
Also all the little shields along the manifolds...same reason suppression.
Back in the day, you wanted to hear 'Wolfman Jack" lol.
ps the antenna is in the rear for the same reason.
Unkahal
To Distributor shield cover
