fans
Old Oct 22, 2019 | 04:46 PM
robroute66's Avatar
robroute66
Default fans
I've got a 78 I've put a big block in. I'm swapping in a 73 fan shroud and would like to use an 18 inch diameter fan. Would this go in place of the 17.5 inch fan or would it not clear? I was also thinking of using one of those 18 inch plastic fans off a Chevy truck, the ones with 9 or more blades. Thoughts?
Old Oct 22, 2019 | 04:55 PM
jkippin's Avatar
jkippin
If you are worried about keeping it cool your best bet would be an aluminum radiator and Spal fan setup. I just did thais to mine and it had a dramatic drop in temperature. I went from a big copper brass radiator to a three core aluminum.
Old Oct 22, 2019 | 04:59 PM
robroute66's Avatar
robroute66
I've done got an aluminum radiator. I do hate electric fans, just want to keep cool cruising and getting the groceries.
To fans
