68 SB lower rad hose
Old Oct 24, 2019 | 05:24 PM
titanle's Avatar
titanle
Default 68 SB lower rad hose
So I had my lower radiator hose blow up on me yesterday , luckily the car was at home and I had just parked it.
is the gates 20813 the correct replacement?
this is the hose that’s on there now
Old Oct 24, 2019 | 07:17 PM
HeadsU.P.'s Avatar
HeadsU.P.
Not a big fan of those "ribbed" re-enforced type hoses. I believe they hinder flow in my opinion. Maybe find something else with a smooth surface inside & out.
Must have an internal support spring too. Keep looking.
Old Oct 24, 2019 | 09:27 PM
titanle's Avatar
titanle
Do all hoses come with the internal spring? Any particular model or will any generic one fit.
Old Oct 24, 2019 | 09:52 PM
MelWff's Avatar
MelWff
20813 is for BB.
SB for manual no AC is 20811
look at the Gates site
Old Oct 25, 2019 | 06:25 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
no they all dont come with the spring now a days. Either pull the spring from the bad hose or find a generic stainless steel spring. There was a thread from a year or two ago talking about springs.
The last hose I looked up actually came with a spring which was nice to see. I havent bought anything yet though
Old Oct 25, 2019 | 08:25 AM
HeadsU.P.'s Avatar
HeadsU.P.
Judging by the look of your old hose, somebody threw away the spring because they would not use both ribbed hose & spring.
Shop around on some Vette vendors for the PROPER HOSE. Then you will know it is the correct diameter, the correct length and has the correct pre-bent form to it. This is not a place to use generic stuff. Do it right.
Try Zip Corvettes, Keen, Wilcox, etc.
Old Oct 25, 2019 | 08:59 AM
Rescue Rogers
It's just a hose spring. When you pull it out it goes straight. It just needs to be close to the inside diameter to keep the hose from collapsing and stainless steel to keep it from rusting
Old Oct 25, 2019 | 08:58 PM
titanle's Avatar
titanle
I found a hose at the local parts shop that looks pretty much identical to the one I removed. It did not have the metal spring inside but instead it has the spring built into it. It fit pretty good, I did have to trim just a tad from the end but it seems to fit just like the old one did.
Old Oct 26, 2019 | 10:53 PM
60 SHARK's Avatar
60 SHARK
I just got the Gates hose this wk,,, no spring,
Old Oct 26, 2019 | 10:55 PM
titanle's Avatar
titanle
The ac delco one has it built in. You can see it protruding out of the hose in a spiral pattern.
Old Oct 27, 2019 | 10:15 AM
Rescue Rogers
you need to hunt around for a hose spring like this
https://www.thepartsplaceinc.com/pro...-17-long/99442
https://www.ebay.com/sch/i.html?_fro...pring&_sacat=0
To 68 SB lower rad hose
