jack, battery and storage compartment key needed
Old Oct 28, 2019 | 02:47 PM
scott1959's Avatar
scott1959
Default jack, battery and storage compartment key needed
Hello,
My 1969 corvette is missing its rear compartment key (round head) for locking the compartments. Is it possible to get a universal replacement that will work?
Only the ignition key came with the car when I purchased it.
Old Oct 28, 2019 | 03:17 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
A locksmith can possibly cut a key for you. Take your rear compartment lock to him/her.
Old Oct 28, 2019 | 04:01 PM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
The same key that is for the rear center compartment also fits the spare tire lock.
Old Oct 28, 2019 | 04:20 PM
HeadsU.P.'s Avatar
HeadsU.P.
I can't remember where I saw them for sale. I think there are 6 or 7 different coded keys for security. Try Ecklers, Corvette America or you can always Google search for a spare key.
Old Oct 29, 2019 | 10:06 AM
SIXTYTWO's Avatar
SIXTYTWO
Remove the door and take it to a local locksmith . There's a code on the side of the lock cylinder and he can make keys with that code.
Old Oct 29, 2019 | 04:06 PM
scott1959's Avatar
scott1959
Is it easy to remove the compartment door?
Old Oct 29, 2019 | 04:10 PM
Greg's Avatar
Greg
Just another Corvette guy
Much easier to just remove the lock itself. One Phillips head screw holds it in place.
Old Nov 4, 2019 | 08:37 AM
scott1959's Avatar
scott1959
Hello,
Thanks for the info.. I removed the Philips screw that seems to hold the protecting bracket on the underside of the compartment lock and removed the bracket, but the lock itself does still not come out? Any suggestions on how to remove it without doing any damage? Do you hit underside of lock with a hammer to dislodge it?
Old Nov 4, 2019 | 09:49 AM
HeadsU.P.'s Avatar
HeadsU.P.
I think some of these answers are assuming the doors open now, accessible. I think your best bet is to remove the hinges first.
Even if you could find a replacement GM key, how do you know which code it is? IDK Just saying, if you can buy a key for $10, a locksmith will likely charge $60.
Shop around on Corvette Americas web site. See if they have keys. How to get the code #.
Old Nov 4, 2019 | 11:31 AM
MelWff's Avatar
MelWff
Originally Posted by scott1959
Hello,
Place a piece of soft wood under the lock and then lightly hit the wood with a small hammer
Old Nov 4, 2019 | 08:09 PM
general ike's Avatar
general ike
2017 C3 of the Year Finalist
St. Jude Donor '20- '21
It might be cheaper to simply buy a new lock with matching key from one of the vendors. Although everything stated above is correct finding a old fashion locksmith that still does this kind of work and still has the codes may not be easy nor cheap depending on were you live. Just cheaper to replace the lock. I have done this twice. Ike
To jack, battery and storage compartment key needed
