1970 corvette brakes
Old Oct 31, 2019 | 08:33 PM
Jhrrat's Avatar
Jhrrat
Default 1970 corvette brakes
I have a 1970 corvette 350 automatic, brake lights are not working, any ideas?
Old Oct 31, 2019 | 08:50 PM
69_Shark's Avatar
69_Shark
Check the fuse, check the bulbs, check the switch at the brake pedal, check wiring is what I’d do in that order.
Scott
Old Nov 1, 2019 | 06:34 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
when you check the fuse, also check for 12 volts.
Old Nov 1, 2019 | 12:27 PM
C3_DH's Avatar
C3_DH
That is where I would start - check the fuse box and if that is good, take a volt meter, take the lens off and see if you have 12 volts to your light (or something very near 12). If your fuse is good and you do not have voltage, you may have a wiring problem...
Old Nov 3, 2019 | 09:28 AM
Dhershkovitz's Avatar
Dhershkovitz
1st Gear
Default Ls7
Good morning Scott.
I am considering an ls7 swap in my c3 vette. I had some questions for you.
Is there an easy way to email you?
Thanks,
David
To 1970 corvette brakes
