1968 Corvette engine ID pad codes
T= Tonowanda
08= August
21= 21st day
IL= 427 390HP
ie, small letter "l" for a number 1, etc. This happened more often than GM would like....
0 8 2 I 1 L
0 is fine, and as expected
8 is fine, and as expected
2 is fine, and as expected
Capital letter I (I cannot find the correct font to show the upper and lower cross bars), used interchangeably with the digit 1 to indicate the number one.
Now here is the interesting part, the digit 1 is being used to represent the capital letter I
L is fine, and as expected
So, the capital letter I is used to represent both the capital letter I, and the digit 1 when an number is needed. Seen this many times, no big surprise.
But, using the digit 1 to represent the capital letter I is somewhat unusual. I don't think it is wrong, or that the stamp is bad, but it is a bit unusual. I do not recall seeing this before, or if I did, I didn't recognize it for what it was.
Good pad stamp, no doubt in my mind, but a bit unusual in that regard.
Next to the 2 should be a 1, next to the L should I
that's why I was questioning.
That is a 1 to the left of the L, not an I. Look at the base of 1 and the top, truly a 1..
I suspect that if we started searching, we would actually find more examples of this sort of thing.
I believe that part of this is very unusual.
The letter I and the digit 1 are often used interchangeably is the ASSEMBLY DATE part of the engine stamp, not in the ENGINE SUFFIX CODE part of the engine stamp.
