72 console
Old Dec 12, 2019 | 07:32 PM
mids4me's Avatar
mids4me
Default 72 console
How do you tell a reproduction console from a GM?
Old Dec 12, 2019 | 09:44 PM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
My original on my 69 is white plastic not black on the inside but not sure about a 72
Old Dec 12, 2019 | 10:30 PM
Greg's Avatar
Greg
Just another Corvette guy
Yes, that looks like black ABS plastic.
Old Dec 13, 2019 | 07:05 AM
Mooser's Avatar
Mooser
I was going to say if it's not busted in the shift plate corners - it's not likely original. But maybe that's just mine
My 72 is a white-ish fiberglass color as well.
M
Old Dec 13, 2019 | 08:52 AM
mids4me's Avatar
mids4me
Thanks for the replies. Looks like it must be a repro.
Old Dec 13, 2019 | 08:57 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Probably, but it's looks like it's in good shape.
Old Dec 13, 2019 | 09:20 AM
Eliredandblack's Avatar
Eliredandblack
On my 73 console you can see where the foam padding was injected after the vinyl was attached to the fiberglass/plastic console. My doors cards, and hard top liners have the same type of product.
Old Dec 13, 2019 | 10:23 AM
fastimes's Avatar
fastimes
St. Jude Donor '19-'20-'21-'22
M
No it's not just yours, lol! Common problem I think. They sell a kit to repair those corners:
68-76 FORWARD SHIFTER CONSOLE REPAIR KIT - FIX MOUNTING TABS ON SHIFT CONSOLE
Old Dec 13, 2019 | 05:50 PM
Mooser's Avatar
Mooser
anything that's busted enough that a vendor creates a repair patch for you just know it was an issue
Mine has a pretty hard life over the years and the top ones were snapped off so I just epoxied some new aluminum pieces into the top corners, much like the kit except from the scrap bin, and drilled new holes to match the shifter-plate. 4 or 5 years and counting...
M
Old Dec 14, 2019 | 01:47 PM
BarryB72's Avatar
BarryB72
In the car, I look at the ridge that runs along the stitching on the edges. I've had a couple repos and the ridge is pretty flat compared to GM
To 72 console
