Winshield tint
Old Dec 16, 2019 | 10:03 AM
thelal1's Avatar
thelal1
Default Winshield tint
Is this usual in older windshields
Is this a usual thing on older windshields? Think about having it replaced.
Old Dec 16, 2019 | 01:12 PM
kingkohlmn's Avatar
kingkohlmn
Veteran: Marine Corps
Do you have tint on the windows? If not then that may be de-lamination.
Old Dec 16, 2019 | 01:16 PM
thelal1's Avatar
thelal1
No tint
Old Dec 16, 2019 | 03:43 PM
jhudec's Avatar
jhudec
Default Ws
Yes
Fairly common delamination. Can be worse when there is rust in the WS frame. The rust can permeate and cause this, but not always.
Old Dec 16, 2019 | 04:14 PM
7T1vette's Avatar
7T1vette
That happens on 'tinted' AND 'non-tinted' factory windshields. Auto windshields are "Safety glass" items. That means there are two layers of tempered glass with a plastic layer between them. This keeps the glass from shattering when damaged.
What you are seeing is the beginning stages of the plastic layer separating from the glass layer(s) at the edges of the windshield. Very normal after about 25-30 years, or more.
Old Dec 16, 2019 | 06:06 PM
jeffwebley's Avatar
jeffwebley
Minor correction here.
Tempered glass breaks into little squares. Side and rear windows are tempered glass.
Heat strengthened glass breaks into large chunks. Mostly used in buildings.
Annealed or raw glass is used in windshields (among other things) and heat formed and laminated.
Old Dec 16, 2019 | 06:27 PM
thelal1's Avatar
thelal1
Default Glass
What is best remedy?
Old Dec 17, 2019 | 01:24 AM
7T1vette's Avatar
7T1vette
Leave it alone, unless it just annoys the he!! out of you. Then replace it.
P.S. Other than when cleaning the windshield/windows so that you actually see that separation, is it noticeable at any other time? This "defect" is not a functional issue.
Old Dec 17, 2019 | 06:19 AM
jhudec's Avatar
jhudec
Leave it, especially if it the original WS.
Old Dec 17, 2019 | 07:44 AM
thelal1's Avatar
thelal1
Default Winshield
Yep you're right, doesn't bother me that much. The cost makes it invisible...
To Winshield tint
